Electronics => Beginners => Topic started by: cyberwasp on January 01, 2020, 03:02:26 pm
I you read my new members intro you'll understand the following.
For the past 2 months I've been watching tutorials on using oscilloscopes. Am slowly getting back into electronics via fixing items for friends and neighbor. I've been gathering a lot of 18650 Li-ion cells. I threw together a charger using a TP4056 module.
Now to my question. Like I said I'm still learning how to use the scope. However, I watched an old Youtube video of a guy using a scope to monitor the voltage and current of the battery he was charging. I would like to do the same. I can monitor the voltage but can't find the appropriate point for the current. The tp4056 he used doesn't have the protection circuits that mine does.
I would have included the link to the video but the previous forum I joined was highly offended when I did that. TIA
Thank you Blue skull Here's the video I referenced https://www.youtube.com/watch?v=wfrm6lbt8Pc&t=626s (https://www.youtube.com/watch?v=wfrm6lbt8Pc&t=626s)
Wouldn't be easier and more numerically tractable to use a pair of DMMs for this kind of thing? Scopes may be as few a 8 bits on the ADC and you may not be using all of them depending on how the front end is built. As a result, any readings you get are of limited resolution.
