Author Topic: Having issues getting an LM4040 reference working  (Read 4527 times)
Offline joeyjoejoeTopic starter
« on: August 30, 2018, 12:25:48 am »
I'm doing some ADC, and I have an LM4040 to set the 5V reference on the arduino to something reliable.
It's an LM4040BIZ-5.0, and I ordered it from DigiKey.
http://www.ti.com/lit/ds/symlink/lm4040-n.pdf
It's a pretty simple reference schematic that I'm trying to use, with a 460ohm resistor. This should give 2.5mA, which is more then the 1mA requirement. But I'm getting 12v at the output. One small (heh) detail, I might have put too much current through it - I'm noticing now the absolute maximum is 10/20mA. The magic smoke was never released... but I guess it's something we need to consider. Maybe I blew it...
« Last Edit: August 30, 2018, 12:29:10 am by joeyjoejoe »
Offline floobydust
Re: Having issues getting an LM4040 reference working
« Reply #1 on: August 30, 2018, 01:28:56 am »
Check your PCB pinout is correct and pin 3 is N/C or connected to pin 2 anode.
12V-5V/460R is high at over 15mA- which is the max. for the LM4040. Try the math again, it should be k ohms.
Otherwise, it might be dead from an overcurrent spike.
The following users thanked this post: joeyjoejoe
« Reply #2 on: August 30, 2018, 01:42:36 am »
Ahh, I see.
Okay, I think it's probably safe to assume I nuked it :)
Online Zero999
  • 0999
« Reply #3 on: August 30, 2018, 07:58:02 am »
You've made an error in your calculations.
I = (VIN -  VREF)/R
It's rated to give 5V at just 65μA, worst case, so why do you need to run it at over 15mA.  How much current does the  ADC need for the reference? Set the current for around 1mA and add a 100nF capacitor in parallel with the reference.
R = (VIN -  VREF)/I = (12 - 5)/0.001 = 7000.
Use the nearest standard value. It doesn't have to be accurate, E6 20% tolerance will do, which gives 6k8.
https://en.wikipedia.org/wiki/E_series_of_preferred_numbers#Lists
Still, I doubt 15mA would fry it. There must be an error somewhere else. Check all the connections and the output voltage again with a 6k8 resistor.
« Reply #4 on: August 30, 2018, 12:46:48 pm »
Gave it a shot with 6k8 - no dice, still 12V. Time to find another batch of items to get from Digikey! :)
Offline exe
  • self-educated hobbyist
« Reply #5 on: August 30, 2018, 04:04:32 pm »
I'd double check polarity (I don't believe it's a diode/zener, I think datasheet shamelessly lies, should be a band-gap).
« Reply #6 on: August 30, 2018, 11:19:20 pm »
I flipped it as well with no success :(
Offline exe
« Reply #7 on: August 31, 2018, 07:09:54 am »
Just in case, one of leads is not connected.
BTW, I buy all (cheap) ICs in more quantity than I need just for this reason.
Offline stj
« Reply #8 on: September 01, 2018, 11:54:48 am »
one revision of the LM4040 datasheet has the wrong pinouts!!
this cost me a couple of devices - i'll try to find which revision is good or bad.
« Reply #9 on: September 03, 2018, 04:32:00 pm »
Ah, !@#. Bottom view... nice.
« Reply #10 on: September 03, 2018, 04:56:54 pm »
Yup, totally working now :) I'm seeing 5.001V on the Fluke 117.
