Author Topic: weird NE555 circuit, found in a cordless drill...  (Read 1130 times)
Offline ELS122Topic starter
« on: March 28, 2021, 04:59:07 am »
I took apart the switch in a cheap broken cordless drill I had... this one wasn't potted in epoxy surprisingly. reverse engineered the circuit... and drew a shematic...
I could've gotten the NE555 pins wrong by 180degrees... idk, it had no notches on it and I'm not too familiar with IC's, or SMD stuff for that matter...
the SOT package too... it had 'A73' writen on it, so I asumed it was some 2SA73- BJT, and for that too I could've gotten the wrong BJT with a diffrent pinout, since it makes no sense how there's like no grid leak, no collector supply, no emitter drain... it just seems like it it wrong af....
I don't know where the pins connected to the mosfet and the big diode since it fell apart when I got it open.
if it helps the diode was a 6A4, and the fet was a 50N06
1203994-0
Offline retiredfeline
Re: weird NE555 circuit, found in a cordless drill...
« Reply #1 on: March 28, 2021, 05:16:16 am »
2SA transistors are PNP. The VCC feed to the 555 doesn't look right.
« Reply #2 on: March 28, 2021, 05:35:00 am »
so I double checked everything again and yes I messed up the circuit a bit... here's the revised shematic
but there's still the transistor is just like floating... I see no path to ground from the emitter, are they using it as a diode perhaps? but why?
edit: yes 4 and 8 are connecter... missed that
« Last Edit: March 28, 2021, 05:47:13 am by ELS122 »
« Reply #3 on: March 28, 2021, 05:48:21 am »
so now after looking at it, it seems that the BJT is used as 2 diodes... so it's like a regular motor driver basically...
Offline mvs
« Reply #4 on: March 28, 2021, 11:02:49 am »
The following users thanked this post: ELS122
« Reply #5 on: March 28, 2021, 12:39:29 pm »
It seems to be some kind of PWM circuit. You should move the resistor network and switch to the left to make it clearer.
Offline Zero999
  • 0999
« Reply #6 on: March 28, 2021, 03:10:49 pm »
Yes, it's probably a dual diode package, rather than a transistor.
The circuit doesn't look quite right. Pin 4 should go to +V.
Here's a schematic of a PWM circuit with a potentiometer. It should be similar to that, but with a switch and discrete resistors.
