Pretty much parroting others, whatever you do with this particular design is likely not going to be any sort of issue.
The caps/resistors in general look a bit funky both in terms of their placement and routing (the upper part esp). This is probably the thing I'd emphasise most here. On this design you got space left and right, but you got parts all over the place to boot. Some other time you might not have the luxury. Learning the skill and habit to optimise the real estate usage, and usually as the result - the visual side of things, will come in handy if/when you proceed to more advanced designs.
No clue what levels of currents you have running there, but for educative purposes might consider beefing up some of the nets at least so that you familiarise yourself with this, if for nothing else.
Ground vias should be as close as possible to the component leads.
Would not run ground tracks on the top side in the first place as you've got the whole bottom plane for this.
Don't place anything close to board edges unless you have to do it for whatever reason. Same applies for the routing. You've pulled the GND plane back nicely, but there's that odd track running beyond it.
Doesn't matter in this kind of design, but consider copper pours on all layers. If and when you do this, remember to stitch those planes together in generous enough manner.
