Multisim files are not backwards compatible. For example, a file created in version 13 cannot be open in version 12 or previous, and there is no option to save files as a previous version.
On the other hand Multisim is forwards compatible, this means you can open older files in newer versions. For example, you can open a version 10 file in Multisim 13, regardless of the versions. Therefore it is also possible to open 14.1 files in Multisim 14.2.
The same rules apply to Ultiboard files.
