Author Topic: What is this component?  (Read 2633 times)
Offline TheGlassesGeekTopic starter
  • I'm an electronics noob :)
« on: May 21, 2015, 07:59:13 am »
I wass working on arduino and found this in a scematic. do any of you know what this is? I searched for it but I got no results.
Offline German_EE
Re: What is this component?
« Reply #1 on: May 21, 2015, 08:13:44 am »
I'm guessing that it's an incorrectly drawn FET.
Warren Buffett
Offline Warhawk
    • Personal resume
« Reply #2 on: May 21, 2015, 08:28:14 am »
This is P - MOS (FET). These simplified schematic symbols are usually used in microelectronics designs.
There is nothing wrong with it:
https://www.intersil.com/en/products/amplifiers-and-buffers/all-amplifiers/amplifiers/ICL7611.html
« Last Edit: May 21, 2015, 08:41:52 am by Warhawk »
Offline Warhawk
    • Personal resume
« Reply #3 on: May 21, 2015, 08:41:24 am »
The magic formula for google image search is "CMOS" design.
http://cmosedu.com/cmos1/bad_design/bad_design7/bad_design_7.htm
And why there is no marking for a source or drain ? Well, in theory FET structure is symmetric and will work both ways if you take care of substrate (body) bias.
http://www.circuitstoday.com/jfet-and-mosfet-comparison
Offline mcinque
  • I know that I know nothing
« Reply #4 on: May 21, 2015, 11:35:33 am »
Why some would connect a DS18B20 with GND and VDD to ground? What I am missing?  :-//
Offline Warhawk
    • Personal resume
« Reply #5 on: May 21, 2015, 11:47:07 am »
You eagle eye !  :-+
Offline PA0PBZ
« Reply #6 on: May 21, 2015, 11:56:57 am »
VDD:          Optional VDD. VDD must be grounded for operation in parasite power mode.
Offline mcinque
« Reply #7 on: May 21, 2015, 11:59:13 am »
hmm.. parasitic power mode, thank you!
