Scope is 20Mhz I don't set that, I just zoom in. I could easily see the noise down at 100uS per division and below. Vertical scale set to 50mV per div. Probe in X10.
As a random experiment I just took my Extech meter out of the tool box, set it and it's probes on the table and switched it to mV range. It's happily reading between 5mV and 40mV AC from thin air.
I mean it could just be my environment. It's always been there. I only suspect it when things aren't playing like they should be.
In this case I was trying to get good voltage readings on the arduino. I'd gone through the external reference, but as one of my voltages goes to 4.99V I tried 5V from a regulator as a reference. It worked but when the USB power was disconnected, leaving the PSU providing 5.00V and not USB providing 5.10V the ADV went nuts and wouldn't read below 1.25V. I take this to mean that AREF must be < Vcc. It works if I put a resistor there, but gives my ceiling voltage of 4.61V
Anyway, while it was reading the other end the reading was scattering around. 0.000V 0.029V 0.000V 0.048V and so on. The actual voltage was 0.042V. Yet at the other end of the scale it was much better within 10mV. However at the lower end, both ADCs in use bounced around nowhere near the actual reading.
I was hoping for more than this from it. I wondered if it's happening to sample some of the noise causing the reading to scatter around.
No matter what I do with it it won't read accurately across it's full 5V (or 4.61V) range. I'd live with +-10mV but it's out by 100mV or more sometimes.
