What about the Proton "Dynamic Power on Demand" system, apparently "Was way ahead of it's time (1980s)"... Delivering like 5x higher burst power than normal power.
"the power amp section has about 6dB of headroom. This receiver is rated at 40 watts, but during instantaneous peaks (up to 200ms), it can deliver up to about 150-160 watts." -about the Proton D940
The D275 car amp can deliver the 'up to 5x higher power' mentioned. But there doesnt seem to be any schematics for that one.
Looking at the schematic for the D940 it just looks to me like a typical class G amp, (the continous type). How does it get so much burst power? is it just because the power supply has a ton of headroom? it uses 10'000uF capacitors for each 74V rail. The big caps are proprietary caps manufactured by Nichicon specifically for Proton.
For the D940 the filter caps for the 34V rails are 2*4700uF for each rail
The D275 uses 10'000uF @ 80V caps for the HV rails, and 2200uF @ 50V caps for the LV rails
Also would you run into beta droop problems at such high currents with BJT output?
Speaking of which, I also learned about secondary breadkdown in BJT's, I presume an advantage of class G is that the risk of this is greatly reduces with class G since the voltage across the conducting output transistor would be much lower than with a typical AB amp circuit, right?
Apparently this technology was patented but I can't find a patent for this.
Here's some articles:
https://worldradiohistory.com/hd2/IDX-Audio/Archive-Stereo-Review-IDX/IDX/80s/HiFi-Stereo-Review-1985-11-OCR-Page-0041.pdfhttps://worldradiohistory.com/hd2/IDX-Audio/Archive-Audio-IDX/IDX/80s/Audio-1987-05-OCR-Page-0051.pdfhttps://youtu.be/eYDHFD5ITa4?t=80He shows the internals a bit in the video.
It doesn't seem like anything special, other than a class G amp.
But I thought output power in amplifiers was limited by the output transistors not being able to pass the current. So is it instead limited by the power supply instead? Would then putting 10'000uF caps on the power rails in a typical power amp make it's burst power skyrocket to like 5x more than normal power?
So the emitter resistor sense protection circuit in typical amps is there to keep the transistors from exceeding their max rated current, and if you put transistors that are the same, except they can pass a lot more current (other specs being the same for example sake), with the protection circuitry removed, if would get super high dynamic burst power? Then the power would be limited by the max voltage swing instead?
And then all that's limiting continous power will be the power supply, and thermals ofc.
Why do many amps have the protection circuitry sensing only the top output transistor? is it for simplicity and cost saving? how reliable would that be?
