There is, but you need a mains transformer with two isolated secondaries. Given that, then you can make two isolated/regulated LM317 supplies, and simply 'stack' them. If won't be as efficient as using an LM317+LM337, as you need 8 rectifier diodes instead of 4, but it will work.
