Author Topic: Nokia lcd 5110 SPI communication with STM32 doesn't work  (Read 1275 times)
Offline mohannadTopic starter
  • Country: eg
« on: September 28, 2017, 10:13:07 pm »
I'm trying to start a simple communication with nokia 5110 LCD using SPI protocol. I'm using SPI2 peripheral on stm32f103c8t6 board but it doesn't work as intended.
The code should intialize SPI preipheral and send two commands to the LCD : first command to use the basic instruction mode and the second to set all segments on.
Here's my code :
#include "stm32f10x.h"                  // Device header
#define NRES              GPIOA->ODR |=  ((((uint16_t)  0x1)  << 8))
#define RES               GPIOA->ODR &=  (~(((uint16_t) 0x1)  << 8))
#define SET_DK            GPIOA->ODR |=  ((((uint16_t)  0x1)  << 9))
#define RESET_DK          GPIOA->ODR &=  (~(((uint16_t) 0x1)  << 9))
void CLK_init (void);
void RCC_init (void);
void GPIO_init(void);
void SPI_init (void);
void LCD_init (void);
void delay(void);
int main(void)
    char volatile a ;
    uint32_t tmp = GPIOB->CRH;
    CLK_init ();
    RCC_init ();
    GPIO_init();
    SPI_init ();
    LCD_init ();
    RESET_DK;
    SPI2->DR = (0x20);                     //LCD COMMAND : BASIC SET , HORIZ ADDRESSING
    a  = SPI2->SR & (((uint16_t)0x1)<<1);  //TXE BIT
    while(a != 0x2)                        //WAIT UNTIL TX BUFFER IS EMPTY
    SPI2->DR = (0x9);                        //E=1 , D= 0 - ALL SEGMENTS ON
    while(1)
void CLK_init(void)
    // 01: HSE oscillator used as system clock
    RCC -> CFGR |=  (uint32_t)0x1;
    RCC -> CFGR &= ~((uint32_t)0x1)  << 1;
    RCC -> CFGR &= ~(((uint32_t)0x7) << 11);
    RCC -> CFGR |=  ((uint32_t)0x1)  << 13;
void RCC_init(void)
    RCC->APB2ENR |= ((uint32_t)0x1)<<0;  //Enable AFIO pin
    RCC->APB2ENR |= ((uint32_t)0x3)<<2;  //Enable ports A,B
    RCC->APB1ENR |= ((uint32_t)0x1)<<14; //ENABLE SPI2
    GPIOB->CRH &= ~(((uint32_t) 0xf)  << 16) ;   //PB12 OUTPUT - AFIO - PUSH PULL
    GPIOB->CRH |=  ((uint32_t)  0xb) << 16  ;   //PB12 OUTPUT - AFIO - PUSH PULL      //////NSS//////
    GPIOB->CRH &= ~(((uint32_t) 0xf)  << 20) ;   //PB13 OUTPUT - AFIO - PUSH PULL
    GPIOB->CRH |=  ((uint32_t)  0xb) << 20  ;   //PB13 OUTPUT - AFIO - PUSH PULL      //////SCK//////
    GPIOB->CRH &= ~(((uint32_t)  0xf) << 24) ;   //PB14 OUTPUT - AFIO - PUSH PULL
    GPIOB->CRH |=  ((uint32_t)  0xb) << 24  ;   //PB15 OUTPUT - AFIO - PUSH PULL      //////MISO//////
    GPIOB->CRH &= ~(((uint32_t) 0xf)  << 28) ;   //PB15 OUTPUT - AFIO - PUSH PULL
    GPIOB->CRH |=  ((uint32_t)  0xb) << 28  ;   //PB15 OUTPUT - AFIO - PUSH PULL      //////MOSI//////
    GPIOA->CRH &= ~(((uint32_t) 0xf)  << 0) ;    //PB8 OUTPUT - GENERAL PURPUSE - PUSH PULL
    GPIOA->CRH &= ~(((uint32_t) 0x1)  << 0) ;    //PB8 OUTPUT - GENERAL PURPUSE - PUSH PULL
    GPIOA->CRH &= ~(((uint32_t) 0xf)  << 4) ;    //PB8 OUTPUT - GENERAL PURPUSE - PUSH PULL
    GPIOA->CRH &= ~(((uint32_t) 0x1)  << 4) ;    //PB8 OUTPUT - GENERAL PURPUSE - PUSH PULL
void SPI_init(void)
    SPI2->CR1  =  0x0000;
    SPI2->CR1 |= ((uint16_t)0x1)<<4;    // Fclk/4
    //SPI1->CR1 |= ((uint16_t)0x1)<<8;  // Enable SSI
    SPI2->CR2 |= ((uint16_t)0x1)<<2;
    SPI2->CR1 |= ((uint16_t)0x1)<<2;    // Master mode
    SPI2->CR1 |= ((uint16_t)0x1)<<15;   // BIDIRECTION
    SPI2->CR1 |= ((uint16_t)0x1)<<14;   // TRANSMIT ONLY
    SPI2->CR1 |= ((uint16_t)0x1)<<6;    // SPI1 enable
void LCD_init(void)
    NRES;                                  //PULLS RESET PIN HIGH
    RESET_DK;                              //PULLS DK PIN LOW - COMMAND MODE
    RES;                                   //PULLS RESET PIN LOW
    delay();
void delay(void)
    uint32_t volatile count = 0 ;
    while( count < 100 )
        count++;
What's really weird is that the LCD sometimes turns 1/3 of its pixels on when I push the reset button , and if I pushed more two times it turns the whole screen on (1/3 each time) and the same when I enter the debug mode.
So what is the wrong with my code?
