I do not know how to answer multiple post in one, so I put it here. (again sorry for the poor housekeeping)
I looked more into the transimpedeance idea, and I hit a snag.
Please see diagram
Presentation1.pdf (124.91 kB - downloaded 17 times.)
The electrochemical cell is here modeled naively as two resisters in series.
Basically, the resistance ? is unknown, variable and intrinsic to the electrochemical cell. So I would think that I am no longer probing current but rather the "potential drop" across ? . Alternatively, I could given up the reference electrode and measure V1 across the electrochemical cell, but then I do not know where to put the current return path for the current sourced by the potentiostat i.e. where to put the negative lead.
The compliance voltage of the potentiostat is +-15V. The dynamic range that I would need should be arround 1pA-10nA. Above this the noise is sufficiency low that we can just use the amp meter of the potentiostat.
