Author Topic: Non-standard resistor value?  (Read 1732 times)
Offline overlordMannyTopic starter
« on: February 14, 2019, 03:53:00 am »
Hi everyone. I'm a bit of a noob. Even though I've been formally trained in electronics by the USAF it's been many, many years since I've done much electronics repair work.
I have an old Nintendo 64 power supply that's giving me no output at all. I'm not terribly familiar with switch mode power supplies, but from what I can understand it looks like I may have an open somewhere on the primary side( no fuses blown). I found a resistor that seems to be reading high at 68.2M ohms. When I look up the color code, (blue, grey, green, gold, green), it looks like it should be 68.5 ohms at .5% tolerance, which is apparently non-standard. Looking at the numerical values, they seem too close to be a coincidence. What am I missing/not understanding. Here's a picture...
« Last Edit: February 14, 2019, 03:24:02 pm by overlordManny »
Offline tooki
Re: Non-standard resistor value?
« Reply #1 on: February 14, 2019, 04:09:56 am »
Could it be a fusible resistor that uses a nonstandard color code, at least for some of the bands? (I think there was a discussion of those on here a few months ago.)
The following users thanked this post: overlordManny
Offline golden_labels
« Reply #2 on: February 14, 2019, 04:14:12 am »
digit1 | digit2 | multiplier | tolerance | temperature coefficient?
That would be: 6.8MΩ, 5%, 20mmp/K.
People imagine AI as T1000. What we got so far is glorified T9.
« Reply #3 on: February 14, 2019, 04:27:53 am »
That correct! I just found this on allaboutcircuits, amazing how you find answers after you post questions.
"Color Code Exceptions
5 Band Resistor with a 4th Band of Gold or Silver
Five band resistors with a fourth band of silver or gold form an exception, and are utilized on specific or older resistors. The first two bands represent the significant digits, the third band is a multiplication factor, the fourth band is for tolerance and the fifth band is for the temperature coefficient (ppm/K)."
Guess that's not my power supply problem. haha The search continues.
