Hi
I was using LM358 as voltage comparator in non inverting configuration
I gave 5V to vcc and 2.5V to inverting pin through a potentiometer
The issue is I am getting a output voltage of approx 3.8V even when the supply to the non inverting terminal is zero
I get output no matter I set the voltage of the non inverting pin zero or less than or more than that of inverting terminal
Also the ic gives the same output when non inverting is given some voltage and inverting is zero
The ic output gets zero only when both inverting and non inverting terminals are zero
Please help me to sort this
I desire to get high output only when the voltage at non inverting is greater than that at inverting i.e 2.5V
Because not all amplifiers can fully reach the power supply range.
The LM358 output range goes from (+V -1.5V) to (-V +1.5V).
So if you power it with 5V and GND, the output will be between 1.5V and 3.5V.
You need a rail-to-rail amplifier. Ex. the LMV358, MCP 602, MCP6002...
Actually, LM358 can swing to near ground or V-.
using the opamp like this is not recommended, attacking in+ directly is to be avoided at least without mastering opamps. for beginners, in- is much simpler to work with
avoid using opamps without any reaction and filtering, i don't want to elaborate because your schematic point the need to watch opamp tutorials first
if you want a voltage value detection, this is what voltage supervisor are made, they do it perfectly at a good cost
Hmm. The 358 should allow GND as input and allow differential input voltages.
Try hooking up a pot to the + input too, slowly change it and see what happens at the output. Perhaps you have a chip that's not really am LM358.
Hi Whales, I tried this but still faced the same issue
What did the output voltage do?
Probably something like:
- fake chip
- damaged chip
- bad breadboard, missing connection somewhere
- you got the pinout wrong
Well, that's what the datasheet says. It it's actually capable of reaching gnd, that's a bonus, but not specified there...
The data sheets say the LM358's output can't go higher than Vcc-1.35V so 3.8V max high output on a 5V supply is about right.
"the common mode voltage range is VCC-1.7 V."
Both inputs should be kept between 0V to Vcc-1.7V, so 0V to 3.3V, before you could say it was faulty, although it looks like the output should still be in the right direction if only one of the inputs is above Vcc-1.7V.
On a breadboard, at least sometimes measure the voltages right at the ICs pins as a check for bad connections.
A more careful reading of the data sheet is in order:
Edit: Actually it even says it on the
front page of the data sheet:
I replaced the opamp with LM393
The issue is when I test the comparator individually ,it works fine, i.e it will give output only when noninverting is greater than inverterting
But when I connect it in the whole circuit the same issue occurs of giving output when noninverting is zero
PLEASE HELP ME TO SORT IT
