Author Topic: Noob question: What is this component?  (Read 1338 times)
Offline Prithul0218Topic starter
« on: January 25, 2019, 03:33:04 pm »
It looks like a capacitor. But 3 pins?
I found it on a brushless motor ESC.
Offline Benta
Re: Noob question: What is this component?
« Reply #1 on: January 25, 2019, 04:32:14 pm »
Ceramic resonator for clock generation.
The following users thanked this post: Prithul0218
Offline Doctorandus_P
« Reply #2 on: January 27, 2019, 10:04:34 am »
I'm not too sure about that component being a ceramic resonator.
Those are usually a lot smaller.
It could be an unusual ceramic low voltage capacitor, or 2 capacitors in 1 SMD package.
If you follow the PCB traces you know for sure.
If it is connected to Vcc it is a capacitor.
If it is connected to the oscillator pins of the uC it is a ceramic resonator.
The following users thanked this post: yashrk, Prithul0218
Online westfw
« Reply #3 on: January 31, 2019, 10:14:25 am »
Nah; Arduino boards have been using especially tiny resonators, but a lot of them are much bigger.(also, that's not as big as it looks.  Assuming 0.8mm pin spacing on the TQFP, it's 4 or 5mm long?)https://www.digikey.com/product-detail/en/abracon-llc/AWSCR-16.00MTD-T/535-9362-2-ND/
