Author Topic: Normal voltage spikes from computer PSU ?  (Read 1084 times)
Offline lordvader88Topic starter
« on: November 24, 2018, 04:56:32 pm »
I'm just checking a 750W PSU that might or might not have problems. It powers up fine, and starts a little dual core PC. Looking at the outputs tho IDK if it's normal or not.
It's switching at ~140kHz
So the 12V rail, I get the inductive ringing of 2.0Vpp max on the 1st ring, 1.25Vpp by the 2nd ring, and by the 6/7 ring it's decayed to next to nothing. Those rings in total span ~600ns, the period of the switching is 7us.
The 5V rail looks the same shape/time wise, with the 1st ring max of 1.84Vpp, 1.33Vpp on the 2nd, and drops off by 6-7 rings.
The ripple looks fine. I'm just wondering if those inductive spikes sound about normal at 2Vpp ?
I could pull the output caps and check ESR. I don't have any proper way to load test these PSUs, this test rig is under well under 300W.
Offline David Hess
  • DavidH
Re: Normal voltage spikes from computer PSU ?
« Reply #1 on: November 24, 2018, 06:50:51 pm »
How did you make the measurement?
It is very easy for common mode switching noise from the power supply to corrupt a single ended measurement where a common ground is used.  The ATX specifications require noise measurements to be done differentially.
You may be able to verify a problem with common mode noise by connecting the oscilloscope probe tip and ground lead to the spot where the ground lead is connected for the measurement.
I would expect 10s to low 100s of millivolts of peak-to-peak noise maximum.
« Reply #2 on: November 24, 2018, 08:17:29 pm »
I ordered diff. probes, they're in the mail.
I'm going to probe my main PSU, see what it looks like.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: November 24, 2018, 09:20:36 pm »
That's not going to affect anything attached to it, and as alluded to, it's more likely common mode.
I strongly suspect the poor bugger can't pass emissions (up the power cord) though.
Seven Transistor Labs, LLC
