I was trying to find a fault in this schematic to find my faulty component.
I tested all the values shown and everything was correct and in spec
I did diode test on CR13, CR14.
Vdrop with the leads facing the normal direction, 0.64v.
Vdrop with the leads facing the wrong direction, 1.715v.
I thought there should be nothing in the wrong direction, but i'm not sure because I'm testing in circuit.
Both diodes show the same measurement, within 0.02v +/-.
Should I replace the diodes? Or are they not the problem?
