Hey everybody. I have a Mean Well RQ-50D which provides +5v, -5v, +24v and -24v.
I intended to test it out before i wired it up to the device it was going to connected to, just to be sure all the voltages were correct, so i wired up the AC plus ground in line with a power switch. When i flipped the power switch the green LED on the RQ-50D lit up for a second then went back away. With the switch set to either on or off, i'm not measuring any AC or DC voltage from any of the screw terminals.
Did I kill it by feeding power to the power supply without any loads connected to the DC output terminals?
Thanks in advance.... I already have another RQ-50D in the mail. I just don't know if i killed it for sure or if i got a faulty unit.
