I had used a 10k ntc thermister for measure the temperature of hot water (~50-70C) for extended periods of time (~30min), leaving the thermister in the water. Now, a few months later, the thermister has a resistance of ~18k at room temperature. I checked another unused thermister from the same batch and it still had a normal resistance of 10k at room temperature. The thermister still works; when I heat it up, the resistance still drops. Is the thermister still usable? Normally it is used in a voltage divider with a 10k resistor but if I changed it to a 18k resistor, would it still work/ be accurate? Also, why would the resistance of it change?
Thanks
