Author Topic: OBD-II Service 0x01, PID 0x02 response.  (Read 1567 times)
Offline firewalkerTopic starter
  • Country: gr
« on: September 16, 2018, 07:05:02 pm »
Does anyone know what the two byte response for the Freeze DTC command contain? I am not able to find any infos.
Alexander.
Offline mikerj
Re: OBD-II Service 0x01, PID 0x02 response.
« Reply #1 on: September 17, 2018, 05:43:54 pm »
PID 02 returns the trouble code that triggered the storing of freeze frame data.
The following users thanked this post: firewalker
  • Country: gr
« Reply #2 on: September 17, 2018, 05:47:06 pm »
Same as Servise $02 PID $02?
Alexander.
Offline HwAoRrDk
« Reply #3 on: September 17, 2018, 05:50:19 pm »
Yes, it is described in the ISO standards document as "DTC that caused required freeze frame data storage", and the two-byte value should be interpreted as a DTC value just as per service 0x03. See further on in the Wikipedia article you showed an excerpt from for how to decode.
If the returned value is 0x0000, then that indicates there is no freeze-frame data.
