Author Topic: obtaining frequency of coil  (Read 905 times)
Offline LaserTazerPhaserTopic starter
« on: September 28, 2019, 02:03:06 am »
Is it as simple as sweeping a coil with sines with an arbitrary generator while the scope is across the coil on FFT mode?
Offline amyk
Re: obtaining frequency of coil
« Reply #1 on: September 28, 2019, 02:06:23 am »
Explain in more detail what you mean by "obtaining frequency" - inductance?
The following users thanked this post: LaserTazerPhaser
Offline Whales
    • Halestrom
« Reply #2 on: September 28, 2019, 02:07:48 am »
N.B. a coil on its own tends not to have any (useful) frequency response, unless you are hunting for things caused by the interactions of inductance with internal parasitic capacitances.  Are you intending to use it with a capacitor to make an LC circuit?
I believe so, just make sure your scope is measuring something useful (eg current into the LC circuit) and ensure that you are aware of whether or not your siggen changes amplitude when you change frequency (depends on the design/quality/age).
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: September 28, 2019, 06:19:39 pm »
If you are looking at the self resonance i think you just need to give it a pulse and see what frequency  it oscillates at.
« Reply #4 on: September 28, 2019, 06:22:03 pm »
This is to obtain coils LC or SRF frequency were capacity is coils parasitic capacitance. The issue is probing it without a resistor which lowers Q offsetting frequency.
Offline Simon
  • Global Moderator
« Reply #5 on: September 28, 2019, 06:25:44 pm »
well if you drive a square wave through it you should see peak signal strength at the resonant frequency.
Offline alsetalokin4017
« Reply #6 on: September 28, 2019, 08:41:56 pm »
And if you look at the completely on-topic and ad-free videos I linked in my mysteriously disappeared post you will see some examples of same.
« Reply #7 on: September 28, 2019, 10:09:48 pm »
Greatly appreciated to the mods who removed the offending new age trash off this topic in the form of youtube videos. Same user of posted youtube videos reports on free energy and overunity. https://overunity.com/profile/tinselkoala.13644/
Mutual inductance should make this simple for exposed coils. For ferrites and high permabile xfmr wound parts it needs to be directly probed.
« Last Edit: September 28, 2019, 10:15:49 pm by LaserTazerPhaser »
