Author Topic: Micro-controllers intel and PIC some very basic questions  (Read 1617 times)
Offline omerkc1Topic starter
  • Country: my
« on: November 25, 2016, 04:28:12 pm »
Hello there! All I know about electronics is from self learning, so go easy on me eh?
I found a two microcontrollers lying around me petroleum lab (intel l7421568b ;  pic 16c64a) and got into reading about what I could possibly do with em.
I was able to find some information on the pic, but nothing on the intel.
So, here are my questions:
1) can I use the same bootloader on the intel as the pic?
2)how are they different from the ATmega328
just by typing this out,I know how stupid these questions sound... but eh, never hurts for a dolt to learn after a few kicks yea?
Offline Ian.M
Re: Micro-controllers intel and PIC some very basic questions
« Reply #1 on: November 25, 2016, 05:48:00 pm »
Google doesn't find anything for thye Intel part number so the odds are that its something old and proprietary, probably mask programmed for a specific application.   Some of Intel's old MCUs could be used with an external EPROM program memory, but EPROMs are a P.I.T.A all of their own, and you loose so many I/O pins to the external memory interface that it isn't worth it compared to modern devices of the same architecture, some of which have built in serial bootloaders.
The PIC16C64A is an EPROM memory midrange PIC.  If its in a plastic package, its essentially worthless as its OTP so you cant erase and reprogram it.  If its in the windowed CERDIP package, it might be worth a bit to someone who is stuck with supporting a legacy product that uses it and already has the development tools, but a compatible programmer + a UV eraser for it will cost you far more than a PICkit 3 and a tube of far more powerful modern PICs.
1. Neither support using a bootloader.
2. That's a question you should try to answer for yourself by comparing the summaries for program and data memory and peripherals in the PIC16C64A and ATmega328P datasheets.  Also note that the PIC needs a minimum of 4 clock cycles per instruction compared to the ATmega's one.
  • Country: my
« Reply #2 on: November 26, 2016, 01:59:32 pm »
Thank you so much for your reply.
I've got loads to lean obviously. buy hey, one step at a time eh!
Offline danadak
« Reply #3 on: November 26, 2016, 02:47:30 pm »
Consider starting with Cypress PSOC. It is a CPU + a lot of analog capability, with a ton
of training videos. a $ 10 board will get you an excellent platform for experimentation.
http://www.digikey.com/product-detail/en/CY8CKIT-059/428-3390-ND/5184557?WT.mc_id=IQ_7595_G_pla5184557&wt.srch=1&wt.medium=cpc&WT.srch=1&gclid=CJati_LUxtACFU1WDQodVfkMnA
The Pioneer board has arduino compatible headers, but is lower ended part in feature set, and more like $ 25.
http://www.cypress.com/documentation/development-kitsboards/cy8ckit-044-psoc-4-m-series-pioneer-kit
For me what stands out is -
1) Routability
2) Fast 12 bit SAR A/D and slow 20 bit DelSig
3) DFB (Digital Filter Block) that is dual channel, handle FIR or IIR filters, or DFB
can be used as a GP fast processor block, similar to RISC block
4) MSI logic elements GUI based and/or the UDB Verilog capability. Eg. the FPGA
like capability
5) Onboard Vref
6) IDAC, VDAC, OpAmps (up to 4), comparator, mixer, switch cap, analog mux....
7) LCD,  COM, UART, I2C, I2S, One Wire, SPI, Parallel, LIN, CAN, BLE, USB
9) Custom components capability, create with schematic capture or Verilog
10) DMA to offload processes like filters, COM, Display
11) ARM M0 (PSOC 4) or M3 (PSOC  5LP) or 8051 core(PSOC 3)
12) Extensive clock generation capabilities
13) All components supported by extensive prewritten APIs
https://www.element14.com/community/thread/23736/l/100-projects-in-100-days?displayFullThread=true
http://www.cypress.com/documentation/code-examples/psoc-345-code-examples
Great video library
Attached component list.  A component is an on chip HW resource.
Free GUI design tool with schematic capture, "Creator". Components have rich API library attached
to each component. Compilers free as well.
PSOC 4 is low end of family, consider 5LP parts as well. PSOC 4 also has arduino footprint boards (pioneer) as well
https://www.elektormagazine.com/labs/robot-build-with-cypress-psoc
http://www.cypress.com/products/32-bit-arm-cortex-m-psoc
Contact the local sales office, "RSM", regional sales manager, and FAE as well, maybe they can give you some stuff as well. Never be afraid to ask. Even contact the Manufacturers Rep, sometimes they can have some boards laying around not being
used.
Regards, Dana.
« Last Edit: November 26, 2016, 02:51:20 pm by danadak »
