If you want to demonstrate ohm's law, get rid of the LED.
That's true. But... I didn't know that. I thought you could take
any circuit, use the supply voltage (for V), the total resistance (for R), and calculate the current. Today I purchased
Make: Electronics, by Charles Platt. The circuit I used was from the book with the exception of the pot values. I didn't have the one he prescribed. He asks you to measure the voltages across the pot and the LED. I observed that they were different of course. He doesn't ask you to check the current with the LED. He gets to current a few pages later AFTER asking you to remove the LED. I felt that he was doing that simply to make it less cumbersome physically. I decided to go ahead and measure the
existing circuit complete with LED. I had three voltages to choose from: the battery, the voltage across the LED, the voltage across the pot. I was dead sure you would use the battery voltage. Now I know better. I'm going to recommend (to the publisher) that they discuss the issue in the next printing. Hobby electronics is LED crazy and I think it would be smart to do the current-flow exercise WITH the LED. Kills two birds with one stone: You learn Ohm's Law
and which voltage to use. All this is of little interest unless you're a stone beginner like me and my grandson. Blind leading the blind.
