I have designed an Electronic Load and I am in the power-on testing stage. Here's that thread:
https://www.eevblog.com/forum/projects/electronic-load-project-ltv171-irfp250-with-kicad-files/I have two lab-type PSUs. But, even combined, they will not reach the proposed design limit of 30v/2a.
Using a car battery was suggested and I think that a reasonable idea. But, I also have a serious charger and using it would be more convenient than disconnecting the car battery... Not to mention the danger of battery explosion, etc.
It is possible to turn off the charger's regulation circuitry, so the charger will not be doing the work that I want the e-load to do. It can supply 14vdc at 55 amps.
I am really just wanting to make sure that I am not about to do something very dangerous. It seems to me that this type of testing is exactly what the e-load is intended for. But, the charger involves mains level power and is tied to earth, so caution seems prudent. The e-load is not tied to earth.
So, is it okay to use the charger for the test? If so, do I need to lift the earth on the charger? Any other precautions needed?
Here are the pertinent parts of the manual.
PRODUCT DESCRIPTION
IOTA DLS Series Power Converter/Battery Chargers convert 120 volts nominal A.C. to 13.6 volts D.C. As a power supply, its tightly controlled regulation allows the user to operate any 12 volt nominal D.C. load up to the converter’s rated output current. As a battery charger, the converter will maintain the battery, delivering its full-rated current when the battery capacity falls sufficiently low. The voltage is set to deliver its maximum current for the necessary period of time that minimizes undue stress to the battery caused by heating of its cells. This helps to ensure the longest possible life of the battery. Over time, as the battery nears its full capacity, the converter will float-charge the battery to prevent self-discharge of its cells.
PROTECTION FEATURES
The IOTA Power Converters/Battery Chargers are designed with high quality components to help ensure years of continuous use. The unit is protected by multiple protection features for a long, trouble-free life. 1) Reverse Battery Polarity Protection. 2) Brown-Out Input Protection. 3) Over-Current Protection - cycle by cycle peak limiting as well as rated current limiting to maximize the life of the converter. 4) Over-Temperature Protection. In addition, it is designed with a unique “proportional” fan control circuit. Fan speed is directly proportional to the converter’s internal ambient temperature. This enables the fan to turn on and off very slowly, minimizing unwanted fan-starting noise.
TWO-STEP VOLTAGE JACK
The two-step voltage jack allows switching from a long-term float voltage of 13.6vdc to a ‘high-stage’ voltage of 14.2vdc. When the included dual voltage plug is inserted in the jack*, the voltage rises to 14.2vdc for occasional fast charging. When the plug is removed, the voltage drops to 13.6vdc to reduce battery water loss. WARNING: To avoid battery damage, remove the Dual Voltage Plug when quickcharging is complete. NOTE: If the unit is equipped with an internal IQ4 smart charger, two-step charging is not needed and the Dual Voltage Jack is disabled.
Thank you, for your help.
