Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
laptop motherboard soldering
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: laptop motherboard soldering (Read 5153 times)
ShadyK
Contributor
on:
November 06, 2013, 03:53:46 pm »
Hi again everyone
because i got such good and helpfull responses from my last post. I would really appriciate some help again please. I want to add LEDS to my laptol case and keyboard. The case modding is not a problem. Its knowning 100percent were to put the cables. Will i just test the connections to my battery connector and run the cables of there with a transistor on the negative? Thanks for the help in advance.
Logged
Terabyte2007
Frequent Contributor
Country:
It is purpose that created us... That defines us..
Re: laptop motherboard soldering
Reply #1 on:
November 06, 2013, 04:11:06 pm »
What are these LEDS for? Power, HD,
Logged
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
ShadyK
Contributor
Reply #2 on:
November 06, 2013, 04:55:59 pm »
I would have leds to illuminate my keyboard and then just tk moddified my casing
Logged
Simon123
Regular Contributor
Country:
Reply #3 on:
November 06, 2013, 05:17:46 pm »
Why dont you solder it to usb?
Logged
G7PSK
Super Contributor
Country:
It is hot until proved not.
Reply #4 on:
November 06, 2013, 05:24:05 pm »
Most laptops will have an unused USB port on the motherboard that you could use without having to use one of the physical port outlet sockets, have a look at the laptop schematic or circuit diagram.
Logged
ShadyK
Contributor
Reply #5 on:
November 06, 2013, 05:46:05 pm »
There will be about 6 leds in total will i have to use a transistor ? And i am a noob at this so would it be easier to solder to usb?
Logged
Terabyte2007
Country:
Reply #6 on:
November 06, 2013, 06:19:41 pm »
You should not need a transistor, but you will need some current limiting resistors depending on where you pick up the Vcc. Coming off the USB will give you about +5V or slightly less depending on your USB driver chip. Keep in mind that the USB will be limited in current (Ranging from apropx. 300mA - 500mA) so keep this in mind when you spec the LEDS and if you plan to still use this port for devices. Personally, I would come off the main +5V rail or regulated output but this depends on your skill level. If you want to get really crazy, you could add some logic and watch for a keypress then turn on the LEDS for a predetermined amount of time with a timer chip, then turn them off again!
Logged
Simon123
Regular Contributor
Country:
Reply #7 on:
November 06, 2013, 07:15:12 pm »
Will you have a switch, so you can turn leds on and off?
But be carefoul, not to desolder any smd caps and resistors while doing this.
Logged
ShadyK
Contributor
Reply #8 on:
November 06, 2013, 07:25:46 pm »
Oooo like a mobile phone keyboard thats got me intreaged how would i go about doing that then? This is my practising ya see im just starting out so i want as much expeirence as possible
Logged
Simon123
Regular Contributor
Country:
Reply #9 on:
November 06, 2013, 08:42:45 pm »
What type of laptop do you have?
Logged
ShadyK
Contributor
Reply #10 on:
November 06, 2013, 09:29:49 pm »
Well its a pooh one because i dont eant to brake my proper one its a samsung r519
Logged
Simon123
Regular Contributor
Country:
Reply #11 on:
November 07, 2013, 05:40:06 am »
Thatl be hard in thin laptop like that.
You could try el wire(pop the buttons of and lay the wire around), but the inverter is pretty big.
Logged
ShadyK
Contributor
Reply #12 on:
November 07, 2013, 12:09:41 pm »
Im still a little bit new so could you explain that a bit more for me. Could i not just run the wires around the casing to where i want the leds to sit? And hot glue the leds in place? Or would that not work?
Logged
amyk
Super Contributor
Reply #13 on:
November 07, 2013, 12:25:12 pm »
Be careful with EL wire, high voltage high frequency can cause EMI issues especially with things like the trackpad.
Logged
Simon123
Regular Contributor
Country:
Reply #14 on:
November 07, 2013, 03:15:32 pm »
You could use leds, but for this small keyboard itll be tight fit.
And how would you get wire from inside to outside? You proably wont drill holes in keyboard?
Logged
ShadyK
Contributor
Reply #15 on:
November 07, 2013, 11:54:14 pm »
Yeah thats what my problem is going to be the case modding but i can fathum that out it was mainly the wiring and the powering thats all because if my keyboard is too thin i was going to mod the top part with leds in too.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
