The 0-2.8v signal comes out of the micro on the mainboard attached.
The LED board seems to have 6 driver circuits for the 6 different colors in the LED. The SOT23 I can't seems to get a datasheet for.
This is what is on the chip
M17201
D1726HC
I assume all the signals are created on the micro, are you saying I could buy a PWM driver and then just take those lines for each color(Could I get an example?)?Do you think the drivers in the IR board are PWM?
Unfortunately I dont have an oscilloscope which makes this a bit annoying.
Thanks for the help
