Author Topic: Why - rectifier polarity reversed by resistor?  (Read 701 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: June 01, 2019, 08:06:14 pm »
I am playing with this alternative rectifier and all seem to work, until I put the right most 10K resistor, do anyone know why?
http://tinyurl.com/yxe2d7zj
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline oPossum
Re: Why - rectifier polarity reversed by resistor?
« Reply #1 on: June 01, 2019, 08:12:47 pm »
Note the warning "4 bad connections"
And you have 24200 uF on the output of an op-amp.
« Reply #2 on: June 02, 2019, 12:48:11 am »
Thanks I am trying to use the capacitor multiplyer that Dave talked about. But it does not look like the DC is getting smooth. Therefore did I try to add som extra capacitors and it sort of work now, but if i add the disconnected cap, the circuit stops working.
The 15K is just a random load.
http://tinyurl.com/yxbgt34a
