I need a temperature sensor for a thermal chamber and it needs to be cheap, both the sensor and the circuitry.
However the typical 2 degrees of accuracy for a thermistor is just too much, I need something with an accuracy of maximum +-1 Degree C, better if a little less.
I could use a thermistor if I knew the error was stable over time, so for example if the real temperature is 25C and the thermistor always reads 27C it wouldn't be a problem, all i have to do is to calibrate the reading. But it needs to read 27C evey single time the temperature is 25C, even after days.
I can't find this information anywhere, both for thermistor and for integrated temperature sensors, i can easily find the specified accuracy but not the stability.
Do you have any info about this? I just need to know if a thermistor is stable over time.
