As of now, the total feedback resistance goes from 180 k to 200 k. If I want to stay in the same range of adjustement, it should now go from 900 k to 1 M. So, with a fixed 1 M resistor, I could be stucked....
And, (good remark !), to get a better adjustement range on high gain, I will replace the trimpot by a 100 k
And so, I'll try to replace R3 (on the schematics, but is R4 in my module), by a 1 M and a 10 M on top of each other (in parallel), giving approx 900 k
. Problem is I only have those in a 1206 format (0805 is required).
Otherwise, a 330 k and a 560 k in series, placed as two facing tombstones.... I'll be creative
If nothing else does, through hole resistors with short leads, but I am afraid of the possible noise.....
Thanks for your help.
I'll post my results here, so that it could be of help for others
