Thank you for the quick answer!
Yes, I need a dimmer operating on the principle of phase control. I have seen a lot of schematics and application notes on the internet, but I feel that the development will take a very long time - and I don't have too much time on my hands. Silent operation is a must for this product - I have tested some wall dimmer boxes with various bulbs and there are some that are noisy and some that are not, which kinda makes me feel that I will have a lot of trial and error involved in the development process.
This product will be for the consumer market.
If I find a product that complies with all other requirements, the potentiometer type would not be that important. I suppose a linear potentiometer would be the preferred choice, maybe even together with a button functionality.
About the dimensions - the smaller the better, but we will build the design around the solution this time, so I could consider many possibilities.. I am holding a dimmer module from a wall dimmer in my hands right now and it is 20x20x50mm not including the tip of the potentiometer - this would be a very good size, for example.
The voltage for this product is 230V 50Hz, yes. But there will probably also be a 120V 60Hz version needed.
"I do not believe that you will find this product except for some dimmers made in China that do not meet the standards."
AC dimmers are such a common thing, for me it feels kinda weird that noone is selling them pre-made (like ICs, for example).
"Have you thought about having it made?"
Do you mean having it designed and made for me by someone else?
Or do you mean designing it and having it manufactured for me?
Anyway, both of these options would take more time and effort that a ready built solution.
And again, thank you for your answer!
