Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Op amp input voltage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Op amp input voltage (Read 433 times)
miketan3904
Contributor
Country:
on:
July 01, 2020, 03:49:49 pm »
Hi. I would like to know if we can apply a voltage higher/ lower than the supply of the op amp to the input of the op amp. For example, if I am powering up the op-amp with a single supply, can i apply a -3V at its input?
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Re: Op amp input voltage
Reply #1 on:
July 01, 2020, 03:57:01 pm »
The input common-mode range is one of the specifications on the op amp data sheet, and varies substantially from part to part.
Most op amps will not tolerate a common-mode input voltage 3 V negative with respect to the negative power terminal.
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #2 on:
July 02, 2020, 02:10:51 am »
Common mode range is separate from the absolute maximum input range.
Most operational amplifiers will not tolerate input voltages which are higher or lower than the supply voltages however there are some exceptions with parts specifically designed to support higher or lower or both input voltages.
Also beware that not all operational amplifiers will tolerate a large difference in voltage between the inputs.
Logged
TimFox
Super Contributor
Country:
Reply #3 on:
July 02, 2020, 02:45:34 am »
Right. Common-mode range is for proper operation, but exceeding the absolute maximum input can irreversibly damage the part. Both are specified on the data sheet.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
