No, I showed how to shoot yourself in the foot
Problem is that the midpoint between U1 and U2 is effectively a virtual ground, so R2+C1 load the feedback resistor R1, resulting in more than unity closed loop gain at high frequencies where C1 impedance is comparatively low. That's not exactly a voltage follower anymore.
It can be fixed by "bootstrapping" the midpoint, by connecting U2 IN- to the input signal, but then U1 has to produce the same swing as U2 and requires the same error voltage at its inputs, hence open loop gain is no longer improved over the baseline single opamp case. But this scheme still appears to improve correction of U2 output stage errors, so perhaps it could have some value for audio and such.
This is all because I tried to be clever and use feedback to control U1's contribution to overall loop gain. People actually build high-gain composites, but they usually use passive RC networks between the opamps to shape frequency response. Maybe for good reason. Look up Samuel Groner's "Low-Distortion, Low-Noise Composite Operational Amplifier" for an example of that.
edit
OK, let's switch the roles and put low-frequency integrator / high-frequency follower feedback network around U2 while running U1 open loop. This appears to be better, at least in sim.
Any ideas if something may still be wrong with it?
