Author Topic: Photo resistor polarity  (Read 1146 times)
Offline queennikki1972Topic starter
  • We all start out as newbie's..be kind
« on: May 09, 2019, 03:34:09 am »
I built this circuit from a book, except it calls for a photo resistor. It claims that it will be louder as light increases, however when i built it, its the opposite. It is louder in the dark. Do photo resistors have some sort of polarity?
Siglent SDS 1202X-E - Heathkit IO-4105 - Dr. Meter 0-30v 5a power supply - 862d+ combo unit - Weller WLC100 - Kunkin KL283 DC load. Not much gear yet.
Offline Jwillis
Re: Photo resistor polarity
« Reply #1 on: May 09, 2019, 03:55:09 am »
The resistance should go down when exposed to light .Check with a ohm meter to confirm.
Offline floobydust
« Reply #2 on: May 09, 2019, 04:04:54 am »
https://youtu.be/1NEIWixNTvI
The frequency changes (goes up with light) because the CdS cell's resistance is lower with light and thus charges the capacitor quicker.
Offline AG6QR
    • AG6QR Blog
« Reply #3 on: May 09, 2019, 05:41:05 am »
Direct answer to your question: no, a CdS cell has no polarity.
That circuit should change its frequency with light level, more light should be higher pitch.  The amplitude shouldn't change much, but depending on the speaker you use, there could be significant volume changes due to the speaker's frequency response curve.
« Reply #4 on: May 09, 2019, 02:19:45 pm »
The speaker I had was not identified as 8 ohms. I tried a different speaker and it worked properly.
