Hey guys,
I been working on self balancing robot for my college project. It's almost done, hardware is working and software is working but I am getting issues with the PID part it balances with bit oscillations which is ohk for such a system but after a certain time this oscillations starts to increase slowly at the certain point it is travelling meters in its oscillations and then ultimately it falls.
I have tried different values last night but still it wasn't stable, in some cases it will balance the bot perfectly but start to move forward initially with low but increasing acceleration and ultimately falls down.
I am using teensy 3.2, MPU6050
I have found no other mpu6050 library/ code works with teensy due to its issues with the avr's wire library
Photo of the hardware is added on this link-
https://yashrk.wordpress.com/2016/04/13/2-update-mini-project/Code base on -
http://www.bajdi.com/building-a-self-balancing-bot/
7
#include <Wire.h>
8
#include "Kalman.h" // Source: [url]https://github.com/TKJElectronics/KalmanFilter[/url]
9
10
Kalman kalmanX; // Create the Kalman instance
11
12
/* IMU Data */
13
int16_t accX, accY, accZ;
14
int16_t tempRaw;
15
int16_t gyroX, gyroY, gyroZ;
16
17
float accXangle;//, accYangle; // Angle calculate using the accelerometer
18
float gyroXangle;//, gyroYangle; // Angle calculate using the gyro
19
float kalAngleX;//, kalAngleY; // Calculate the angle using a Kalman filter
20
21
unsigned long timer;
22
uint8_t i2cData[14]; // Buffer for I2C data
23
float CurrentAngle;
24
25
// Motor controller pins
26
const int AIN1 = 3; // (pwm) pin 3 connected to pin AIN1
27
const int AIN2 = 9; // (pwm) pin 9 connected to pin AIN2
28
const int BIN1 = 10; // (pwm) pin 10 connected to pin BIN1
29
const int BIN2 = 11; // (pwm) pin 11 connected to pin BIN2
30
31
int speed;
32
33
// PID
34
const float Kp = 4;
35
const float Ki = 1;
36
const float Kd = 1;
37
float pTerm, iTerm, dTerm, integrated_error, last_error, error;
38
const float K = 1.9*1.12;
39
#define GUARD_GAIN 10.0
40
41
#define runEvery(t) for (static typeof(t) _lasttime;(typeof(t))((typeof(t))millis() - _lasttime) > (t);_lasttime += (t))
42
43
44
void setup() {
45
pinMode(AIN1, OUTPUT); // set pins to output
46
pinMode(AIN2, OUTPUT);
47
pinMode(BIN1, OUTPUT);
48
pinMode(BIN2, OUTPUT);
49
Serial.begin(57600);
50
Wire.begin();
51
i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
52
i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
53
i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
54
i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
55
while(i2cWrite(0x19,i2cData,4,false)); // Write to all four registers at once
56
while(i2cWrite(0x6B,0x01,true)); // PLL with X axis gyroscope reference and disable sleep mode
57
58
while(i2cRead(0x75,i2cData,1));
59
if(i2cData[0] != 0x68) { // Read "WHO_AM_I" register
60
Serial.print(F("Error reading sensor"));
61
while(1);
62
63
64
delay(100); // Wait for sensor to stabilize
65
66
/* Set kalman and gyro starting angle */
67
while(i2cRead(0x3B,i2cData,6));
68
accX = ((i2cData[0] << 8) | i2cData[1]);
69
accY = ((i2cData[2] << 8) | i2cData[3]);
70
accZ = ((i2cData[4] << 8) | i2cData[5]);
71
accXangle = (atan2(accY,accZ)+PI)*RAD_TO_DEG;
72
73
kalmanX.setAngle(accXangle); // Set starting angle
74
gyroXangle = accXangle;
75
timer = micros();
76
77
78
void loop() {
79
runEvery(25) // run code @ 40 Hz
80
81
dof();
82
if (CurrentAngle <= 180.2 && CurrentAngle >= 179.8)
83
84
stop();
85
86
else{
87
if (CurrentAngle < 230 && CurrentAngle > 130)
88
89
Pid();
90
Motors();
91
92
else
93
94
stop();
95
96
97
98
99
100
void Motors(){
101
if (speed > 0)
102
103
//forward
104
analogWrite(AIN1, speed);
105
analogWrite(AIN2, 0);
106
analogWrite(BIN1, speed);
107
analogWrite(BIN2, 0);
108
109
else
110
111
// backward
112
speed = map(speed,0,-255,0,255);
113
analogWrite(AIN1, 0);
114
analogWrite(AIN2, speed);
115
analogWrite(BIN1, 0);
116
analogWrite(BIN2, speed);
117
118
119
120
void stop()
121
122
123
124
125
126
127
128
void Pid(){
129
error = 180 - CurrentAngle; // 180 = level
130
pTerm = Kp * error;
131
integrated_error += error;
132
iTerm = Ki * constrain(integrated_error, -GUARD_GAIN, GUARD_GAIN);
133
dTerm = Kd * (error - last_error);
134
last_error = error;
135
speed = constrain(K*(pTerm + iTerm + dTerm), -255, 255);
136
137
138
void dof()
139
140
while(i2cRead(0x3B,i2cData,14));
141
142
143
144
tempRaw = ((i2cData[6] << 8) | i2cData[7]);
145
gyroX = ((i2cData[8] << 8) | i2cData[9]);
146
gyroY = ((i2cData[10] << 8) | i2cData[11]);
147
gyroZ = ((i2cData[12] << 8) | i2cData[13]);
148
149
double gyroXrate = (double)gyroX/131.0;
150
CurrentAngle = kalmanX.getAngle(accXangle, gyroXrate, (double)(micros()-timer)/1000000);
151
timer = micros();
152
