Author Topic: Op amp supply drawing large current.  (Read 601 times)
Offline Joe_echoTopic starter
« on: October 03, 2023, 05:53:05 pm »
I have some tl074cn chips that I'm experimenting with and trying to refresh my memory on their operation.
I have them hooked up to a single supply rail with 12v and ground which I believe should work, however the supply is drawing a large amount of current almost like a short circuit.
Am I being a muppet and missing something vital?
Offline Manul
  • Country: lt
Re: Op amp supply drawing large current.
« Reply #1 on: October 03, 2023, 06:55:07 pm »
Obviously something is very wrong. Have you double checked the pinout? Can you post schematic?
« Reply #2 on: October 03, 2023, 07:19:13 pm »
I have checked the pinout several times just to make sure its not me.
Here is the schematic
Offline Manul
  • Country: lt
« Reply #3 on: October 03, 2023, 07:29:58 pm »
Generally it would be better if you would give numbers, no epithets, but I assume you mean really high current like 1A or 3A. In that case I can only suggest to double check pinout again and try another (new) IC. Current one might be already irreversibly damaged.
Online Kim Christensen
« Reply #4 on: October 03, 2023, 07:35:05 pm »
But what is the pinout? Your schematic doesn't show it.
It should be something like this:
Offline magic
« Reply #5 on: October 03, 2023, 07:37:45 pm »
The schematic is sensible.
If the circuit draws more than a few mA, something is clearly not the way you think.
Wrong pinout.
Damaged chip.
Wrong part (maybe fake chip?).
Reversed PSU.
Bad PSU ammeter.
« Reply #6 on: October 03, 2023, 07:40:16 pm »
Sorry, yes the pinout of my device matches. Vcc= pin 4, Vee= pin 11.
I believe they maybe fake ICs.
« Reply #7 on: October 03, 2023, 07:40:56 pm »
Yes, 2amp was drawn before my OCP kicked in.
Offline magic
« Reply #8 on: October 03, 2023, 07:43:54 pm »
Any pictures of the chips and/or the exact test setup?
