But that's why these meters are dangerous, right? If you had been measuring a 480V multi-kiloamp circuit on the 10A setting (accidentally, or something), there wouldn't have been any fuse at all (much less the fancy safety fuse that ought to be there), and the whole thing would have turned into an "exploding wire" phenomena that would have killed you! (um... Right.)
