Author Topic: Opamp basics - electret mic peak detector  (Read 3056 times)
Offline Zbig
« on: November 05, 2013, 01:51:40 am »
Hi everyone
I was looking for a solution for an electret microphone amp/peak detector and came across this While I think the guy has made a great job at explaining this, I'm not sure I properly understand why he has intentionally introduced a DC offset on U1 by using virtual ground equal to Vcc/2 (
), an offset he has to cancel later on. Is it because the microphone signal could swing below ground or above Vcc (or could it? I'm not sure) otherwise? Or maybe it's there to bias the D3 diode above its Vf so the signal doesn't have to "shoot through" it, i.e. detector isn't effectively limited to V > 0.6V?
I'd appreciate any help in understanding this.
« Last Edit: November 05, 2013, 01:54:46 am by Zbig »
Online w2aew
    • My YouTube Channel
Re: Opamp basics - electret mic peak detector
« Reply #1 on: November 05, 2013, 02:30:08 am »
Hi everyone
It's mainly because many op amps, like the LM324 he showed) have an input common mode range that does NOT include the supply rails.  In other words, the voltage at the input must be between the supply rails.
For more info on this, see my video on this topic:
FAE for Tektronix
Offline Zbig
« Reply #2 on: November 05, 2013, 11:49:31 am »
That is a great tutorial, thank you! :-+
Online w2aew
« Reply #3 on: November 06, 2013, 02:38:40 am »
Thanks.  Since the topic was on a peak detector, you might also enjoy this video that I put together:
FAE for Tektronix
Offline Zbig
« Reply #4 on: November 06, 2013, 05:36:32 pm »
I certainly did, thanks!
