Poll
I have a signal that is 5mA rms. I need to convert this to 5V with a DC bias which has to be given to the arduino ADC. I need your help in designing a simple opamp circuit that can do the following
convert the 5mA RMS signal to 5V peak to peak with a DC offset such of 5V.
0 (0%)
thats it
1 (100%)
Total Members Voted: 1
Author Topic: opamp current to voltage converter  (Read 877 times)
Offline shiva kumar
  • Country: in
« on: February 17, 2017, 08:29:18 am »
Offline Zero999
  • 0999
Re: opamp current to voltage converter
« Reply #1 on: February 17, 2017, 09:57:14 am »
I wouldn't recommend that. It would give you a 0 to 10V volt output, which is too high for the ADC. You need 5V peak to peak with an offset of 2.5V.
Where is the 5mA signal coming from?
Is it purely AC? I.e. no DC bias on the current signal?
If so and the input impedance doesn't need to be really low, this could be done passively with a couple of resistors, forming a potential divider, and a capacitor.
5mARMS = 5*2*20.5 = 14.14mAP-P
We want to scale that to 5V peak to peak, which can be done with a resistor:
R = V/I = 5/0.01414 = 353.55
If we use a potential divider and a 5V supply to bias it around 2.5V, then the resistor values need to be doubled, as the input impedance is equal to both resistors in parallel. R = 353.55 * 2 = 707R1
« Last Edit: February 17, 2017, 01:32:28 pm by Hero999 »
Offline danadak
« Reply #2 on: February 17, 2017, 01:29:24 pm »
Here is a tool you can use to calc vales to generate offset and handle the AC input signal.
http://masteringelectronicsdesign.com/differential-amplifier-output-common-mode-voltage-calculator/
Regards, Dana.
