So I decided that I wanted to make a powered USB cable.
The layout goes something like this; Wallwart USB charger -> VCC, GND -> Female USB <- D+,D-,GND <- Laptop
So my laptop's ground will be referenced to the charger's ground, or in other words I'm referencing the grounds of 2 USB busses together.
I just wanted to make sure that this would not cause some sort of ground loop, or power contention. So does this should potentially harmful, or should this work just fine?
