Hello,
I turn to you Again as I have some question regarding charging of NiMH cells with a small solar cell. I want to install some LEDS etc. in my daugther playhouseto make the house more fun. But as I want to make some of my prjects off grid thought that all this could be driven by a small solar panel.
I have educated myself a Little on the various battery types, and cannot see how I can charge the large capacity of the cells
properly with a trickle of 5V of 10-100mA. and also I want to use NiMH and the deltaV will probably be undetectable in this way.
http://batteryuniversity.com/learn/article/charging_nickel_metal_hydrideI then considered using the Circuitboard from a solar lamp, but think it will be underspected and inadequate and quite frankly I fail to see how these solar lamps charge the cells probably.
http://www.talkingelectronics.com/projects/SolarLight/Solar5vSupply.html Can any one point me in the right direction?
Thank you in advance
Mikael
Copy paste from my "technical" document.
Idea:
Wire a playhouse with some different leds, contacts etc. and use a solar panel to charge a battery cell pack which drives everything. Include timers for cutoff to save power.
• Solar panel > circuit > battery > switches and timers > load
Desired Equipment
a 5v/100ma solar panel
• 0.5W/ panel in full light pr. panel
4 NiMH batteries in series (AA) (use other chemistry?)
• AA = 4.8v * 2.6Ah = 12,5wh / 45kw
• Can drive 125leds for 1hr, so plenty of power
Timers (lights 30min, oven, dishwasher etc. 5min)
• MCU atmega168, latching transistors – probably the least complex solution
• NE555 delay circuits – might use many as individually wired, but easy to expand.
• capacitor to transistor base(darlington), cons: graduate turn off.
Problems to be addressed
How to make a circuit that don’t kill the batteries.
