Author Topic: opamp simulation  (Read 4641 times)
Offline promachTopic starter
opamp simulation
« on: April 13, 2019, 12:39:57 am »
Is the following open loop transient simulation of opamp correct ?
Re: opamp simulation
« Reply #1 on: April 13, 2019, 07:14:19 am »
Ok, I understood why the output is pulled to the high voltage side.
The culprit is M11. Vgd of M11 is 1.2V-0.25V ~= 1V. How to make M11 to be in saturation region ?
« Reply #2 on: April 13, 2019, 07:26:36 am »
Here you go :
* modified for use with LTSpice; DM 8/19/2008
* 0.18u CMOS process
* NMOS transistor model name: NM
* PMOS transistor model name: PM
.subckt NM D G S B
+params: W=10u L=1u
M1 D G S B NM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL NM NMOS LEVEL=49
************************* SIMULATION PARAMETERS ************************
* format    : LTspice
* model     : MOS BSIM3v3
*                        TYPICAL MEAN CONDITION
+VERSION = 3.1            TNOM    = 27             TOX     = 4.1E-9
+XJ      = 1E-7           NCH     = 2.3549E17      VTH0    = 0.354505
+K1      = 0.5733393      K2      = 3.177172E-3    K3      = 27.3563303
+K3B     = -10            W0      = 2.341477E-5    NLX     = 1.906617E-7
+DVT0W   = 0              DVT1W   = 0              DVT2W   = 0
+DVT0    = 1.6751718      DVT1    = 0.4282625      DVT2    = 0.036004
+U0      = 327.3736992    UA      = -4.52726E-11   UB      = 4.46532E-19
+UC      = -4.74051E-11   VSAT    = 8.785346E4     A0      = 1.6897405
+AGS     = 0.2908676      B0      = -8.224961E-9   B1      = -1E-7
+KETA    = 0.021238       A1      = 8.00349E-4     A2      = 1
+RDSW    = 105            PRWG    = 0.5            PRWB    = -0.2
+WR      = 1              WINT    = 5e-9              LINT    = 2.351737E-8
+DWG     = 1.610448E-9
+DWB     = -5.108595E-9   VOFF    = -0.0652968     NFACTOR = 2.4901845
+CIT     = 0              CDSC    = 2.4E-4         CDSCD   = 0
+CDSCB   = 0              ETA0    = 0.0231564      ETAB    = -0.058499
+DSUB    = 0.9467118      PCLM    = 0.8512348      PDIBLC1 = 0.0929526
+PDIBLC2 = 0.01           PDIBLCB = -0.1           DROUT   = 0.5224026
+PSCBE1  = 7.979323E10    PSCBE2  = 1.522921E-9    PVAG    = 0.01
+DELTA   = 0.01           RSH     = 6.8            MOBMOD  = 1
+PRT     = 0              UTE     = -1.5           KT1     = -0.11
+KT1L    = 0              KT2     = 0.022          UA1     = 4.31E-9
+UB1     = -7.61E-18      UC1     = -5.6E-11       AT      = 3.3E4
+WL      = 0              WLN     = 1              WW      = 0
+WWN     = 1              WWL     = 0              LL      = 0
+LLN     = 1              LW      = 0              LWN     = 1
+LWL     = 0              CAPMOD  = 2              XPART   = 0.5
+CGDO    = 7.7E-10        CGSO    = 7.7E-10        CGBO    = 1E-12
+CJ      = 1.010083E-3    PB      = 0.7344298      MJ      = 0.3565066
+CJSW    = 2.441707E-10   PBSW    = 0.8005503      MJSW    = 0.1327842
+CJSWG   = 3.3E-10        PBSWG   = 0.8005503      MJSWG   = 0.1327842
+CF      = 0              PVTH0   = 1.307195E-3    PRDSW   = -5
+PK2     = -1.022757E-3   WKETA   = -4.466285E-4   LKETA   = -9.715157E-3
+PU0     = 12.2704847     PUA     = 4.421816E-11   PUB     = 0
+PVSAT   = 1.707461E3     PETA0   = 1E-4           PKETA   = 2.348777E-3
.subckt PM D G S B
+params: W=10u L=1u
M1 D G S B PM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL PM PMOS LEVEL=49
* format    : LTSPICE
+XJ      = 1E-7           NCH     = 4.1589E17      VTH0    = -0.4120614
+K1      = 0.5590154      K2      = 0.0353896      K3      = 0
+K3B     = 7.3774572      W0      = 1E-6           NLX     = 1.103367E-7
+DVT0    = 0.4301522      DVT1    = 0.2156888      DVT2    = 0.1
+U0      = 128.7704538    UA      = 1.908676E-9    UB      = 1.686179E-21
+UC      = -9.31329E-11   VSAT    = 1.658944E5     A0      = 1.6076505
+AGS     = 0.3740519      B0      = 1.711294E-6    B1      = 4.946873E-6
+KETA    = 0.0210951      A1      = 0.0244939      A2      = 1
+RDSW    = 127.0442882    PRWG    = 0.5            PRWB    = -0.5
+WR      = 1              WINT    = 5.928484E-10   LINT    = 3.468805E-8
+DWG     = -2.453074E-8
+DWB     = 6.408778E-9    VOFF    = -0.0974174     NFACTOR = 1.9740447
+CDSCB   = 0              ETA0    = 0.1847491      ETAB    = -0.2531172
+DSUB    = 1.5            PCLM    = 4.8842961      PDIBLC1 = 0.0156227
+PDIBLC2 = 0.1            PDIBLCB = -1E-3          DROUT   = 0
+PSCBE1  = 1.733878E9     PSCBE2  = 5.002842E-10   PVAG    = 15
+DELTA   = 0.01           RSH     = 7.7            MOBMOD  = 1
+CGDO    = 7.11E-10       CGSO    = 7.11E-10       CGBO    = 1E-12
+CJ      = 1.179334E-3    PB      = 0.8545261      MJ      = 0.4117753
+CJSW    = 2.215877E-10   PBSW    = 0.6162997      MJSW    = 0.2678074
+CJSWG   = 4.22E-10       PBSWG   = 0.6162997      MJSWG   = 0.2678074
+CF      = 0              PVTH0   = 2.283319E-3    PRDSW   = 5.6431992
+PK2     = 2.813503E-3    WKETA   = 2.438158E-3    LKETA   = -0.0116078
+PU0     = -2.2514581     PUA     = -7.62392E-11   PUB     = 4.502298E-24
+PVSAT   = -50            PETA0   = 1E-4           PKETA   = -1.047892E-4
Online iMo
  • Country: va
« Reply #3 on: April 13, 2019, 07:45:18 am »
It looks like it works, provided you will create a feedback loop with defined closed loop gain, DC offset etc.
« Reply #4 on: April 13, 2019, 07:47:40 am »
Could you explain more on your feedback circuit ?
Online iMo
  • Country: va
« Reply #5 on: April 13, 2019, 07:54:39 am »
« Reply #6 on: April 13, 2019, 08:13:58 am »
I have updated my opamp circuit with negative feedback and the output voltage is now less than 2.5V
And all mosfets are in saturation.
Please correct me if wrong
Note: I have attached the updated opamp.asc
Offline Wimberleytech
« Reply #7 on: April 13, 2019, 11:55:48 pm »
OK, lets peal the onion.
Start with bias.  I do not think this is what you intended with M10.  Eliminate Vb1 and short gate and drain of M10.  That will bias it and mirror Ib1 to the other current sources.
Next, you common mode input is almost at ground.  You can often get away with this when driving a pch diff pair.  But in the feedback configuration, you might have a problem.
« Last Edit: April 14, 2019, 03:09:25 pm by Wimberleytech »
The following users thanked this post: promach
« Reply #8 on: April 13, 2019, 11:58:56 pm »
The mosfet_018.lib is posted in this forum thread. I think third post. Look carefully.
I do not understand this. Could you explain using pictures ?  Why almost at ground ?
Ok
« Reply #9 on: April 14, 2019, 12:14:44 am »
Oh, the circuit has so little gain-bandwidth product. Why ?
Offline Jay_Diddy_B
« Reply #10 on: April 14, 2019, 12:22:45 am »
See attached model.
You need to take the inputs off ground. You can't amplify a negative signal.
Regards,
Jay_Diddy_B
Offline Jay_Diddy_B
« Reply #11 on: April 14, 2019, 12:30:30 am »
For the loop response. Use this model.
You will get:
Regards,
Jay_Diddy_B
« Reply #12 on: April 14, 2019, 12:31:04 am »
I deleted that comment right after posting it.  You saw it before I deleted.
Offline Jay_Diddy_B
« Reply #13 on: April 14, 2019, 12:40:12 am »
Here is an interesting thing to try.
Step the bias current:
You will see you get higher GBW for higher Ibias.
Regards,
Jay_Diddy_B
« Reply #14 on: April 14, 2019, 01:25:12 am »
In your opamp_JDB_bode_plt.asc , why DC 0.6V input stimulus for Vin+   ?
And why are you not using large LC for DC feedback ?
Offline Jay_Diddy_B
« Reply #15 on: April 14, 2019, 02:01:54 am »
The op-amp will only work properly if both inputs are within the common mode range and the output is between the supply rails.
If I step the input voltage and measure the Bode plot:
I have changed the feedback to be a voltage follower, that is a gain of +1. A negative input would require the output to be negative. It can't go negative because we only have a positive supply. So the output would be near zero and there would be no gain.
If the input is 0V, the circuit will work for positive half-cycles, but not negative half-cycles. If the input is positive, the circuit works properly.
I get these results:
If I look in the time domain, transient analysis, and I step the voltage and apply a 100mV peak 1kHz sinewave, is see this. You can see that this op-amp doesn't work if the output is required to go negative.
You can also see that this op-amp has a 'defect' called phase reversal when the inputs are near or just below zero.
The choice of using an LC or positioning the voltage source like I did is preference.
Jay_Diddy_B
« Last Edit: April 14, 2019, 02:12:54 am by Jay_Diddy_B »
Offline Jay_Diddy_B
« Reply #16 on: April 14, 2019, 02:27:31 am »
Hi further to my last post, consider these circuits:
In one I am just using the voltage source and in the other I am using the large inductor and capacitor to close the FB loop.
If I look at the results:
In both cases I get 80dB which is 10000, the gain of the amplifier being tested. The phase is different. In one case I am measuring the inverting input, so I get -180 in the other the non-inverting input so I get 0 degrees.
Regards,
Jay_Diddy_B
« Reply #17 on: April 14, 2019, 12:20:23 pm »
Why is that so for the "near zero" case ?
See this updated schematics.
« Last Edit: April 14, 2019, 12:33:35 pm by promach »
« Reply #18 on: April 14, 2019, 03:22:05 pm »
I tweaked your design a little bit.  Improved the cascode stack.
« Reply #19 on: April 15, 2019, 12:55:16 am »
here is your opamp3.asc
Why are you using small LC (L1, C3) ?
Could you also explain analytically on cascn, cascp and biascn ?
I have done some modification to your opamp3.asc and put it side-by-side to my latest opamp.asc
I am bit curious on how to improve the phase margin of your opamp3.asc (left)
« Last Edit: April 15, 2019, 12:59:17 am by promach »
« Reply #20 on: April 15, 2019, 01:00:04 am »
L and C in that schematic have no impact during transient...they are there for the ac simulation, but for transient unity gain, I kinda make them invisible.  Easier than deleting components and then adding them in later.
I did not investigate phase margin.
What phase margin are you wanting to achieve?
« Last Edit: April 15, 2019, 01:10:08 am by Wimberleytech »
« Reply #21 on: April 15, 2019, 01:32:41 pm »
Is it possible to achieve phase margin of 70 degrees with opamp3.asc ?
« Reply #22 on: April 15, 2019, 02:00:18 pm »
You can increase the two compensation capacitors, or you can reduce the gain (load it with a 10k resistor).
I created the bias string before making any other tweaks...thinking I might need several bias references.  In the end I only needed but two of them (the two cascodes) but left the string intact.
« Reply #23 on: April 15, 2019, 02:26:57 pm »
For improving phase margin of opamp3.asc , I use an extra series resistor to put a zero near the unity gain frequency.
but then, good accurate resistor is hard to fabricate.
So, let me ask: anyone have any idea on how to replace both the ideal current source and the extra resistor with a mosfet in ohmic region without using any extra bias voltage source ?
In other words, is it possible to use constant gm bias circuit in your opamp3.asc or my opamp.asc circuit ?
« Last Edit: April 15, 2019, 02:29:37 pm by promach »
« Reply #24 on: April 15, 2019, 03:35:50 pm »
Yes.  Both of your references are sound.
