Author Topic: opamp simulation  (Read 4637 times)
Offline promachTopic starter
Re: opamp simulation
« Reply #25 on: April 16, 2019, 10:32:15 am »
For the Improvements_in_biasing_and_compensation_of_CMOS_opamp (second reference link), why the author break open the connection between gates of M3A and M3B ?
And how to derive the inequality expression (14) in the document ?
« Last Edit: April 16, 2019, 10:50:31 am by promach »
Offline Wimberleytech
« Reply #26 on: April 16, 2019, 01:11:52 pm »
Set P3 < P1 and simply do the algebra.
Eq 14 appears to have an error...should be gm2b in numerator, not gm2a
The following users thanked this post: promach
« Reply #27 on: April 17, 2019, 03:00:49 am »
I will check your advice regarding the inequality expression, but why set P3 < P1 ? Is it dominant pole compensation or something else ?
I try to incorporate the author schematics (Figure 6 in the second reference link) into the opamp, but it resulted in erroneous bode plot
Which part is wrong in the schematics ?
« Reply #28 on: April 18, 2019, 11:45:07 am »
yes, essentially
ALWAYS check bias points before even looking at your ac response.  In this case, your biasing is broken.
« Last Edit: April 18, 2019, 11:48:53 am by Wimberleytech »
« Reply #29 on: April 19, 2019, 01:25:38 am »
See the following circuit :
I am having problem using the miller lead compensation (M24 mosfet in triode region)
Any help ?
When I saw this 90MHz bandwidth opamp OPA838, I am inspired to do the same, but my current circuit bandwidth is only 10MHz.
« Last Edit: April 19, 2019, 01:47:56 am by promach »
« Reply #30 on: April 19, 2019, 05:46:59 am »
I managed to obtain unity-gain bandwidth = 275MHz , phase margin = 76 degrees , Gain = 93 dB , Power dissipation = 366 uW
« Last Edit: April 19, 2019, 06:13:17 am by promach »
« Reply #31 on: April 20, 2019, 09:53:58 am »
Wait, I tried setting P3 < P1 , but I am getting totally different result from expression 14.
I think you have wrong interpretation of expression 14 ?
