Is the following open loop transient simulation of
opamp correct ?
Ok, I understood why the output is pulled to the high voltage side.
The culprit is M11. Vgd of M11 is 1.2V-0.25V ~= 1V. How to make M11 to be in saturation region ?
Here you go :
* modified for use with LTSpice; DM 8/19/2008
* 0.18u CMOS process
* NMOS transistor model name: NM
* PMOS transistor model name: PM
.subckt NM D G S B
+params: W=10u L=1u
M1 D G S B NM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL NM NMOS LEVEL=49
************************* SIMULATION PARAMETERS ************************
* format : LTspice
* model : MOS BSIM3v3
* TYPICAL MEAN CONDITION
+VERSION = 3.1 TNOM = 27 TOX = 4.1E-9
+XJ = 1E-7 NCH = 2.3549E17 VTH0 = 0.354505
+K1 = 0.5733393 K2 = 3.177172E-3 K3 = 27.3563303
+K3B = -10 W0 = 2.341477E-5 NLX = 1.906617E-7
+DVT0W = 0 DVT1W = 0 DVT2W = 0
+DVT0 = 1.6751718 DVT1 = 0.4282625 DVT2 = 0.036004
+U0 = 327.3736992 UA = -4.52726E-11 UB = 4.46532E-19
+UC = -4.74051E-11 VSAT = 8.785346E4 A0 = 1.6897405
+AGS = 0.2908676 B0 = -8.224961E-9 B1 = -1E-7
+KETA = 0.021238 A1 = 8.00349E-4 A2 = 1
+RDSW = 105 PRWG = 0.5 PRWB = -0.2
+WR = 1 WINT = 5e-9 LINT = 2.351737E-8
+DWG = 1.610448E-9
+DWB = -5.108595E-9 VOFF = -0.0652968 NFACTOR = 2.4901845
+CIT = 0 CDSC = 2.4E-4 CDSCD = 0
+CDSCB = 0 ETA0 = 0.0231564 ETAB = -0.058499
+DSUB = 0.9467118 PCLM = 0.8512348 PDIBLC1 = 0.0929526
+PDIBLC2 = 0.01 PDIBLCB = -0.1 DROUT = 0.5224026
+PSCBE1 = 7.979323E10 PSCBE2 = 1.522921E-9 PVAG = 0.01
+DELTA = 0.01 RSH = 6.8 MOBMOD = 1
+PRT = 0 UTE = -1.5 KT1 = -0.11
+KT1L = 0 KT2 = 0.022 UA1 = 4.31E-9
+UB1 = -7.61E-18 UC1 = -5.6E-11 AT = 3.3E4
+WL = 0 WLN = 1 WW = 0
+WWN = 1 WWL = 0 LL = 0
+LLN = 1 LW = 0 LWN = 1
+LWL = 0 CAPMOD = 2 XPART = 0.5
+CGDO = 7.7E-10 CGSO = 7.7E-10 CGBO = 1E-12
+CJ = 1.010083E-3 PB = 0.7344298 MJ = 0.3565066
+CJSW = 2.441707E-10 PBSW = 0.8005503 MJSW = 0.1327842
+CJSWG = 3.3E-10 PBSWG = 0.8005503 MJSWG = 0.1327842
+CF = 0 PVTH0 = 1.307195E-3 PRDSW = -5
+PK2 = -1.022757E-3 WKETA = -4.466285E-4 LKETA = -9.715157E-3
+PU0 = 12.2704847 PUA = 4.421816E-11 PUB = 0
+PVSAT = 1.707461E3 PETA0 = 1E-4 PKETA = 2.348777E-3
.subckt PM D G S B
+params: W=10u L=1u
M1 D G S B PM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL PM PMOS LEVEL=49
* format : LTSPICE
+XJ = 1E-7 NCH = 4.1589E17 VTH0 = -0.4120614
+K1 = 0.5590154 K2 = 0.0353896 K3 = 0
+K3B = 7.3774572 W0 = 1E-6 NLX = 1.103367E-7
+DVT0 = 0.4301522 DVT1 = 0.2156888 DVT2 = 0.1
+U0 = 128.7704538 UA = 1.908676E-9 UB = 1.686179E-21
+UC = -9.31329E-11 VSAT = 1.658944E5 A0 = 1.6076505
+AGS = 0.3740519 B0 = 1.711294E-6 B1 = 4.946873E-6
+KETA = 0.0210951 A1 = 0.0244939 A2 = 1
+RDSW = 127.0442882 PRWG = 0.5 PRWB = -0.5
+WR = 1 WINT = 5.928484E-10 LINT = 3.468805E-8
+DWG = -2.453074E-8
+DWB = 6.408778E-9 VOFF = -0.0974174 NFACTOR = 1.9740447
+CDSCB = 0 ETA0 = 0.1847491 ETAB = -0.2531172
+DSUB = 1.5 PCLM = 4.8842961 PDIBLC1 = 0.0156227
+PDIBLC2 = 0.1 PDIBLCB = -1E-3 DROUT = 0
+PSCBE1 = 1.733878E9 PSCBE2 = 5.002842E-10 PVAG = 15
+DELTA = 0.01 RSH = 7.7 MOBMOD = 1
+CGDO = 7.11E-10 CGSO = 7.11E-10 CGBO = 1E-12
+CJ = 1.179334E-3 PB = 0.8545261 MJ = 0.4117753
+CJSW = 2.215877E-10 PBSW = 0.6162997 MJSW = 0.2678074
+CJSWG = 4.22E-10 PBSWG = 0.6162997 MJSWG = 0.2678074
+CF = 0 PVTH0 = 2.283319E-3 PRDSW = 5.6431992
+PK2 = 2.813503E-3 WKETA = 2.438158E-3 LKETA = -0.0116078
+PU0 = -2.2514581 PUA = -7.62392E-11 PUB = 4.502298E-24
+PVSAT = -50 PETA0 = 1E-4 PKETA = -1.047892E-4
It looks like it works, provided you will create a feedback loop with defined closed loop gain, DC offset etc.
Could you explain more on your feedback circuit ?
I have updated my opamp circuit with negative feedback and the output voltage is now less than 2.5V
And all mosfets are in saturation.
Please correct me if wrong
Note: I have attached the updated opamp.asc
OK, lets peal the onion.
Start with bias. I do not think this is what you intended with M10. Eliminate Vb1 and short gate and drain of M10. That will bias it and mirror Ib1 to the other current sources.
Next, you common mode input is almost at ground. You can often get away with this when driving a pch diff pair. But in the feedback configuration, you might have a problem.
The mosfet_018.lib is posted in this forum thread. I think third post. Look carefully.
I do not understand this. Could you explain using pictures ? Why almost at ground ?
Ok
Oh, the circuit has so little gain-bandwidth product. Why ?
See attached model.
You need to take the inputs off ground. You can't amplify a negative signal.
Regards,
Jay_Diddy_B
For the loop response. Use this model.
You will get:
Regards,
Jay_Diddy_B
I deleted that comment right after posting it. You saw it before I deleted.
Here is an interesting thing to try.
Step the bias current:
You will see you get higher GBW for higher Ibias.
Regards,
Jay_Diddy_B
In your opamp_JDB_bode_plt.asc , why DC 0.6V input stimulus for Vin+ ?
And why are you not using large LC for DC feedback ?
The op-amp will only work properly if both inputs are within the common mode range and the output is between the supply rails.
If I step the input voltage and measure the Bode plot:
I have changed the feedback to be a voltage follower, that is a gain of +1. A negative input would require the output to be negative. It can't go negative because we only have a positive supply. So the output would be near zero and there would be no gain.
If the input is 0V, the circuit will work for positive half-cycles, but not negative half-cycles. If the input is positive, the circuit works properly.
I get these results:
If I look in the time domain, transient analysis, and I step the voltage and apply a 100mV peak 1kHz sinewave, is see this. You can see that this op-amp doesn't work if the output is required to go negative.
You can also see that this op-amp has a 'defect' called phase reversal when the inputs are near or just below zero.
The choice of using an LC or positioning the voltage source like I did is preference.
Jay_Diddy_B
Hi further to my last post, consider these circuits:
In one I am just using the voltage source and in the other I am using the large inductor and capacitor to close the FB loop.
If I look at the results:
In both cases I get 80dB which is 10000, the gain of the amplifier being tested. The phase is different. In one case I am measuring the inverting input, so I get -180 in the other the non-inverting input so I get 0 degrees.
Regards,
Jay_Diddy_B
Why is that so for the "near zero" case ?
See this updated schematics.
I tweaked your design a little bit. Improved the cascode stack.
here is your opamp3.asc
Why are you using small LC (L1, C3) ?
Could you also explain analytically on cascn, cascp and biascn ?
I have done some modification to your opamp3.asc and put it side-by-side to my latest opamp.asc
I am bit curious on how to improve the phase margin of your opamp3.asc (left)
L and C in that schematic have no impact during transient...they are there for the ac simulation, but for transient unity gain, I kinda make them invisible. Easier than deleting components and then adding them in later.
I did not investigate phase margin.
What phase margin are you wanting to achieve?
Is it possible to achieve phase margin of 70 degrees with opamp3.asc ?
You can increase the two compensation capacitors, or you can reduce the gain (load it with a 10k resistor).
I created the bias string before making any other tweaks...thinking I might need several bias references. In the end I only needed but two of them (the two cascodes) but left the string intact.
For improving phase margin of opamp3.asc , I use an extra series resistor to put a zero near the unity gain frequency.
but then, good accurate resistor is hard to fabricate.
So, let me ask: anyone have any idea on how to replace both the ideal current source and the extra resistor with a mosfet in ohmic region
without using any extra bias voltage source ?
In other words, is it possible to use
constant gm bias circuit in your opamp3.asc or my opamp.asc circuit ?
In other words, is it possible to use constant gm bias circuit in your opamp3.asc or my opamp.asc circuit ?
Yes. Both of your references are sound.
