Hi All,
This is my first foray into analogue circuits so I would appreciate somebody commenting on my plan.
I'm building a power monitor for my solar + battery camping kit. I would like to monitor current from the solar panel to the battery, current from the battery to load and voltage at the battery.
Analogue data capture will be via a PIC with 5V VDD as the voltage reference. The LP2950 has tight enough tolerances for my needs. I'll calibrate results in the digital realm.
I've selected the LM324 op-amp because it is designed for single supply and is linear down to 0V. I'm expecting close to a 25:1 gain on the voltage across the shunts.
Thanks,
Chris
