You need to really include more information. Like where did you put that value ?
anyway in most openbk installs you will need to create a autoexec.bat file to setup the device a example below
(goto device web page, select lauch web app, select file system, select create file autoexec.bat)
typical autoexec.bat for openbk/tuya mcu based device.
startDriver TuyaMCU
startDriver tmSensor
startDriver NTP
ntp_setServer 192.168.10.1
ntp_timeZoneOfs 2
tuyaMcu_setBaudRate 115200
setChannelType 1 toggle
setChannelType 2 Voltage_div10
setChannelType 3 Power
setChannelType 4 Current_div1000
setChannelType 5 Frequency_div100
setChannelType 6 ReadOnly
setChannelType 7 Temperature
setChannelType 8 ReadOnly
setChannelType 9 ReadOnly
//ch 1 (dpid 1) power relay control
linkTuyaMCUOutputToChannel 1 bool 1
addChannel 1 1
//ch 2(dpid 20) voltage
linkTuyaMCUOutputToChannel 20 1 2
//ch 3(dpid 19) power watts
linkTuyaMCUOutputToChannel 19 1 3
//ch 4 (dpid 18)current Amps
linkTuyaMCUOutputToChannel 18 1 4
//ch 5 (dpid (133) frequency
linkTuyaMCUOutputToChannel 133 1 5
//ch 6 (dpid 102) energy cost used
linkTuyaMCUOutputToChannel 102 1 6
// ch 7 (dpid 135) temp
linkTuyaMCUOutputToChannel 135 1 7
//ch 8 (dpid 134) power factor
linkTuyaMCUOutputToChannel 134 raw 8
//ch 9 (dpid 123) energy consumed
linkTuyaMCUOutputToChannel 123 1 9
then you need to add a mqtt user to your Home assistant setup with user/pass and put that in the config mqtt section
(main device web page, config, config mqtt)
finally you need to add mqtt config to configuration.yaml
example setup
mqtt:
sensor:
- unique_id: "ph3_current_a"
state_topic: 'obk1AF0C347/4/get'
unit_of_measurement: 'A'
value_template: '{{ (value | int)/1000 }}'
- unique_id: "ph3_voltage"
state_topic: 'obk1AF0C347/2/get'
unit_of_measurement: 'V'
value_template: '{{ (value | int)/100 }}'
- unique_id: "ph3_power"
state_topic: 'obk1AF0C347/3/get'
device_class: energy
unit_of_measurement: 'W'
state_class: total_increasing
- unique_id: "Phase Three Factor"
name: 'ph3_pf P/Factor'
state_topic: 'obk1AF0C347/8/get'
unit_of_measurement: 'pF'
- unique_id: "ph3_freq"
name: 'PH3 Frequency'
state_topic: 'obk1AF0C347/5/get'
unit_of_measurement: 'Hz'
- unique_id: "ph3_power_usage_total"
name: 'PH3 T/Power Used'
state_topic: 'obk1AF0C347/9/get'
unit_of_measurement: 'kWh'
you can also go the much harder route of TunaHACS or similar but they all require tuya logins and such.
darkspr1te
