Hi.
I was testing some BT136 Triacs, that have been used in some projects, using two LCR T4 board, one from fleebay and other from local distribuitor . Both read fine some of the triacs, identifing properly its pins but some of them are being detected as NPN transistors ... Should i assume this ones are faulty or make a DUT with low power such as a light dimming circuit to check them out?
Edit forgot to place image of the LCR T4.
- LCR T4 H
- LCR T4
Both are powered by NIMH 9V battery same brand and model, not clear about charge status... but results are consistent in both units.
