Hi OK about Lead free and i stand corrected if all on this topic are using lead free but a suspect not
I use both, depends on the job.
The line ( Honestly, for most soldering, it makes not an iota of difference whether one uses leaded or lead-free. ) i wonder if other agree with you considering mixing is not recommended
What’s unclear to you?
For most soldering jobs, one won’t notice any substantial difference (the entire opposition to lead-free being that it’s “hard” to use). I.E. the difficulty level is the same.
As for not mixing: yeah, so don’t mix them. Certainly not in a joint, but better not in an entire device. Rework should be done using the same kind originally used. If a leaded joint has to be switched to lead-free (if somehow you absolutely, positively cannot get any leaded solder), then it should ideally be “flushed” with fresh solder several times to remove any traces of lead.
“It makes not an iota of difference” was referring to the process, not the product.
ok the person that clams to be his job and quotes (If, at this point, you can't manage hand-soldering with lead-free solder, then maybe it's time to consider another hobby.)
I think this is harsh and not in the spirit of helping
A lot of us are growing tired of the constant, largely unfounded whining about lead-free.
From the whining you’d think it was a million times worse, and it’s just not. Is it AS nice to work with as leaded? No, all else held equal. But other factors play a bigger role, like the iron, tip, the joint itself, and the flux. An easy joint is still going to be easy with lead-free, and a difficult joint would still be difficult with leaded.
my only response is my repair and rework is often to deal with dry or cracked solder joints that were made using lead solder also a do not deal with the domestic market
manly test and measurement and the Defence market but I am open to advise on the best lead free solder that is available so more open minded to lead free after reading this topic
For repair you really need to have both anyway, so…
There are plenty of discussions here on solder recommendations, including earlier in this thread.
