Author Topic: Low frequency oscillator  (Read 1638 times)
Offline epaelectronicTopic starter
« on: May 28, 2021, 09:30:27 pm »
Hello.
What would be the best way to get a stable 7-8Khz tunable oscillator?
Preferably a voltage controlled one.
What I have in mind currently is using a 4060 to divide down a 4Mhz crystal that is being slightly tuned with a varactor diode.
Would this kind of arrangement get me to the 1Khz frequency span I need?
Offline BrianHG
Re: Low frequency oscillator
« Reply #2 on: May 28, 2021, 09:52:12 pm »
The 4046 is the easiest way, I know of.
https://hackaday.com/2015/08/07/logic-noise-4046-voltage-controlled-oscillator-part-one/
http://www.learningaboutelectronics.com/Articles/4046-voltage-controlled-oscillator-VCO-circuit.php
Yup, that's the cheapest and easiest.  Also, if you only need 5v or 3.3v, you can use the 74HC4046 if it is easier to get.  Just one word of warning, configure the chip with some headroom.  IE, if you need 7-8Khz, tune it for a range from 6Khz to 9Khz.  The IC can drift a little over time and temperature.  Also, the cap which you use to set the oscillator frequency should be an NPO variant so that the capacitor value will be immune to ambient temperature.
If you need precision, it can be complicatedly done with a cheap 1$ MCU.  Such a solution properly done would guarantee that with the voltage input at 0v, you will get dead on 7KHz, and with the voltage in at VCC, you will get exactly 8KHz.  Practically 0 drift as a reference crystal source's drift would be measured in the parts-per-million.
Offline Benta
« Reply #3 on: May 28, 2021, 11:19:02 pm »
Sorry, but I'm trying to wrap my mind around the suggestions here. I've worked a lot with the 4046 (call me "4046-lover"), but for this application it's the last chip in the world I'd select.
The 4046 VCO is not very precise nor stable. It relies on the feedbacl loop in a PLL.
BrianHG introduced the idea of a $1 MCU.
A much better idea. Find one with ADC, use the timer to divide down to what you need controlled by the ADC voltage.
No continuous frequency sweep, but should do what you need.
Otherwise you'll need to provide MUCH more information on your needed spec.
The following users thanked this post: BrianHG
Online Zero999
  • 0999
« Reply #4 on: May 29, 2021, 09:00:59 am »
Well, I did say the easiest, not the best.
Experience with this kind of request tells me, they normally want to avoid an MCU.
How about the LTC6990?
https://www.mouser.co.uk/datasheet/2/609/LTC6990-1776026.pdf
Online Kleinstein
« Reply #5 on: May 29, 2021, 11:01:10 am »
The trim range for a cystal oscillator is too small, more like 0.1% of the frequency.  It would be more an LC oscillator with varactor diode at the 4060.
Online Zero999
  • 0999
« Reply #6 on: May 29, 2021, 05:40:20 pm »
One solution could be to use two HF oscillators, a fixed one, modulated by a VCO and the beat frequency demodulated to give the low frequency output. It's not the simplest solution though.
Offline Benta
« Reply #7 on: May 29, 2021, 06:26:05 pm »
The right device would be the Philips NE566, but it's obsolete for decades (if it's a one-off, you might find some NOS somewhere).
Here's a link to the datasheet, it might give you an idea on how to roll your own with a couple of opamps.
https://html.alldatasheet.com/html-pdf/17982/PHILIPS/NE566/244/1/NE566.html
Online Zero999
  • 0999
« Reply #8 on: May 29, 2021, 09:48:57 pm »
How about the LM339?
The circuit is on page 10, figure 17 of the ST data sheet.
https://www.st.com/resource/en/datasheet/lm139.pdf
Offline Benta
« Reply #9 on: May 29, 2021, 10:54:46 pm »
Basically a copy of the NE566. Could work.
Offline emece67
« Reply #10 on: May 30, 2021, 01:41:17 pm »
« Last Edit: August 19, 2022, 04:28:34 pm by emece67 »
Offline David Hess
  • DavidH
« Reply #11 on: May 31, 2021, 04:23:37 am »
Dividing down a crystal oscillator source will not allow much tuning range.  If you need crystal stability, then two crystal oscillator outputs could be mixed to produce a stable variable low frequency output.
The more modern option is a crystal oscillator driving a DDS generator which can take many forms.
Online Zero999
  • 0999
« Reply #12 on: May 31, 2021, 10:49:40 am »
Yes, I suppose it is similar to the circuitry in the NE566. It's a shame the IC was discontinued, but obvious why.
