R2 has a suspicious black line on it, could be cracked.
Those resistors use
EIA-96 marking.
Don't measure them in-circuit, desolder one side and slightly rotate it so one side becomes isolated.
05D = 100K
18C = 15K
If broken, the controller feedback might read 0V, setting the output to 100% and blowing everything up.
The resistor ratio is a bit strange:
0.6*(1+(100/15)) = 4.6V
What are those wires instead L1?
You cannot measure the voltage without it, all you will read is 12V spikes and kill everything connected to it.
