Author Topic: Help with getting an old Quartz resonator going  (Read 615 times)
Offline iamsethTopic starter
« on: December 10, 2024, 03:42:35 pm »
I picked up an old Quartz resonator from Ebay. This morning I started on a Pierce oscillator to bring it to life though I can't figure out which values I ought to use for R1, C1, and C2.
Ordinarily I'd just try things until I got it working but I'm moving more carefully because the resonator has sentimental value and I've read that the feedback might cause damage.
My goal is to just get it ringing and graph it on a scope.
The part was produced by a family member's outfit I'm guessing anywhere from 1930 to 1950 and I haven't been able to find a datasheet on it.
This is the Ebay location with some pictures of the component. https://www.ebay.com/itm/267042258669
Any help greatly appreciated.
Offline Smile2016
Re: Help with getting an old Quartz resonator going
« Reply #1 on: December 10, 2024, 04:23:19 pm »
I would start with 4.7Meg + 2x 22pF. A schematic would help. Without a datasheet you can use a cheap VNA [you can get a NanoVNA-H4 from Amazon before Christmas ~ 50-100bucks ] to get resonator's parameters....
Online edavid
« Reply #2 on: December 10, 2024, 04:40:59 pm »
Yes, please post your schematic.
You may have to open the case and clean the spring contacts.  These old crystals are not fragile.
« Reply #3 on: December 10, 2024, 05:08:23 pm »
I've attached a image of a schematic with what I thought would be a basic way to get it to do something interesting. I bought the linked VNA just now. Should be here in 8 days. Thanks for the recommendation.
Thanks for the tip. I'll crack her open later. When you say not fragile, do you mean not easily physically broken, electrically, or both?
Online edavid
« Reply #4 on: December 10, 2024, 05:25:38 pm »
What is the part number of the inverter IC?  4.7K seems too low for CMOS and too high for TTL.
It should oscillate without the capacitors.
Both.
Offline Smile2016
« Reply #5 on: December 10, 2024, 05:26:20 pm »
Resistor should be MegaOhm magnitude not KiloOhm... so 4.7..10MegaOhm  range...CMOS
« Last Edit: December 10, 2024, 05:29:14 pm by Smile2016 »
Offline CaptDon
  • Country: is
« Reply #6 on: December 10, 2024, 10:50:12 pm »
What inverter are you using? What is the frequency of the crystal? With a CMOS or TTL family inverter you can't possibly hurt the crystal. They were used in vacuum tube oscillators that pushed as much as 10 milliamps of crystal current. You may have better luck using a 7404 or 74ls04. Two gates as the oscillator and wire the remaining gates in parallel as a high drive capability buffer. 4.7K is a sensible value for a 7404.
Online edavid
« Reply #7 on: December 11, 2024, 03:13:54 am »
Photo shows 1.043 MHz.
Not really, since the input current can be 1.6mA.
Online Zero999
  • 0999
« Reply #8 on: December 11, 2024, 09:15:12 am »
Assuming it's CMOS, use an unbuffered gate i.e. 4069, 4007, 74HCU04, rather than the 4001, 4011, 74HC04 which are all buffered.
Buffered gates have three amplifiers in series, which can form a ring oscillator, causing it to oscillate at a much higher frequency.
I recommend an IC specifically designed for this such as the, 74LVC1404 or 74LVC1GX04, which have an unbuffered gate for the oscillator, followed by a buffered gate to isolate the load from the oscillator.
https://www.ti.com/lit/ds/symlink/sn74lvc1404.pdf
https://www.ti.com/lit/ds/symlink/sn74lvc1gx04.pdf
Offline CaptDon
  • Country: is
« Reply #9 on: December 11, 2024, 03:08:50 pm »
eDavid, ever looked at any of the older arcade video games from Atari and such? They used standard 7404 since LS was not yet common and I have seen anything from 2.2K to 4.7K. The inverter will force itself into a linear area which makes oscillation possible. Calculations based on 1.6ma are meaningless when you want to run a logic device in a linear area. With the 2.2K or slightly higher the inverter is forced into a 'gray' undefined state and the crystal's phase shift combined with the unstable operating area of the logic device creates the frequency sustaining oscillation. Often these circuits work well with 3rd overtone crystals and you have to be careful because sometimes a fundamental circuit will suddenly shift to the third overtone!
Online edavid
« Reply #10 on: December 11, 2024, 03:30:11 pm »
The attached Altair 680b oscillator is the kind of circuit I remember using, with 470ohm resistors across the TTL inverters.
Too bad we seem to have lost OP  :-//
