Author Topic: Ordered DMM hook probe tips, but they're threaded ?  (Read 1545 times)
Offline lordvader88Topic starter
« on: July 10, 2018, 08:22:46 pm »
I ordered some Uni-T DMM retractable hook type probes tips off ebay, expecting that they'd slide onto any standard DMM. But they're threaded and take maybe 3/16" or 3-4mm. If the item page said that, I missed it.
Maybe they are for some oscilloscope probes ? Or do people make quality DMM probes with interchangeable tips screwed on ?
For now it's back to the little cheap ones that sell for pennies. The spring-loaded hook end is great, but not they way they fit on probes. I take off the plastic end cap and just run alligator clips back to the DMM
Offline JS
  • Country: ar
Re: Ordered DMM hook probe tips, but they're threaded ?
« Reply #1 on: July 10, 2018, 08:43:24 pm »
I have an inexpensive kit of probes where the wires had a female thread on rach end and attachtments had the screw, a red and a black wires and a ton of attachtments, like bananas, alligator, conventional dmm probes, small pointy, lugs, etc. I bought them back in the day when I only had one dmm and no sortage of probes. Recently I've ordered a bunch of connectors and made a bunch of leads using 1mm and 1.5mm electrical high temp silicon wire and some with thin (0.25mm?) "tester leads" silicon wire. I've forgotten about the screw tips but I guess they could come handy as you can't have enough probes...
JS
If I don't know how it works, I prefer not to turn it on.
Offline Old Printer
« Reply #2 on: July 10, 2018, 09:57:33 pm »
I have a Simpson 260 Model 7 analog multi-meter, the factory leads are threaded at the base of the metal probe tip, and come with a pair of threaded alligator clips.  It is the first set of leads I have had like that, but if I didn't have the clips I might never have noticed. With all of the thread options it could be an adventure finding a matching set of leads.
Offline iainwhite
  • Measure twice...
« Reply #3 on: July 10, 2018, 10:04:35 pm »
Probemaster do this - they use an 8-32 thread for the accessories
e.g. http://probemaster.com/8000-series-test-lead-master-kits/
Online IconicPCB
« Reply #4 on: July 10, 2018, 10:21:31 pm »
If the tips are threaded.... You are screwed
The following users thanked this post: tooki, james_s
Offline Brumby
« Reply #5 on: July 11, 2018, 12:21:47 am »
How long did it take you to come up with that one?
(There's always one ... at least)
Annoyed I didn't come up with it first...
Offline radioFlash
« Reply #6 on: July 11, 2018, 02:47:50 am »
« Reply #7 on: July 11, 2018, 03:51:20 am »
Hmm, in the meantime I might wrap some wire or something on there to jam it on a probe.
Oh well, I'm certainly not mailing them back to China
Offline drussell
  • Hardcore Geek
« Reply #8 on: July 11, 2018, 01:28:39 pm »
My ancient set of Mueller probes that I use on my main meter also has the threaded accessories.  I think they're all usually 8-32 thread...
Offline Calambres
    • Piso-Tones
« Reply #9 on: July 11, 2018, 04:04:31 pm »
I had the vary same issue. Bought a couple of hooks for 2mm DMM probes from ebay. The photos were very precise in that they were not threaded but indeed they were!
Cannot link 'em as they have disappeared from the bay, replaced by 4mm threaded ones.
I complained to the seller and they partially refunded  :palm:
Then I bought a pair of Uni-T DMM probes that were compatible with the hooks  ::)
https://www.ebay.com/itm/UNI-T-UT-L27-Multimeter-test-extension-lead-male-thread-probe-10A-CAT-II-1000V-X/282699908732?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
